Author Subject: Fitting Front Lowering Springs !!!
the pumpkin king
I have had a good look the FAQ and tried quite a few variations on the search. Is there a post in the Suspension section or a FAQ on fitting lowering springs.
Posted 7th Sep 2010 at 17:09
bennn
Clicky
Cherry Red 306 HDI
Posted 7th Sep 2010 at 17:16
the pumpkin king
Thanks. Now I see why. Did not think to look for top mount / bearing.Roll eyes ... Should have gone to Specsavers ..
Posted 7th Sep 2010 at 17:22
the pumpkin king
Can someone re-up the pic's on this FAQ. I would be most appreciative. As the FAQ section seems to be missing something when there is just a blank space.
Posted 7th Sep 2010 at 17:34
bennn
Think the pics have been deleted mate, get cracking with it and you should soon be able to pick up which bit goes where!
Cherry Red 306 HDI
Posted 7th Sep 2010 at 17:51
the pumpkin king
Job done. Only prob's I had were, one of the top mount bearings is shot so will need to replace + noticed that the outboard drive shaft Gaiter is burst both on the same side as well, DAMM. Must admit though Rich E had the best advice about jacking up the hub. Top Class.
Posted 8th Sep 2010 at 01:46
honestly3k
Im soon going to be attempting to fit some Bilstein B4's and Eibach 30mm lowering springs. Is it a tough job? First time on suspension here. Think i will be buying new top mounts aswell for this job.
But am i ok using all the old washers/seals etc in the old suspension?
Going to be borrowing spring compressors from the old man and giving it a bash.
Posted 8th Sep 2010 at 01:51
honestly3k
Would be great if i could find a blow-up diagram of suspenstion struts and spring etc so i have something to refer to when im doing it! :S
jeffers Forum Admin
As said above, use the guide to remove the strut, and once you strip the strut down it will become obvious what goes where!Wink
Team Running Engine again!
Team Negative Camber!
Posted 8th Sep 2010 at 03:03
the pumpkin king
I think what would have been very handy would have been a PDF to download. For this and all the other FAQ. With access to both the text and pic's this would be a very simple operation to do.
Posted 8th Sep 2010 at 15:10
