Author Subject: Hybrid arb's
chrisd306
Right I bought an arb but it doesn't look that good to be honest, anybody got a pic of there's before fitting so I can compare it to mine please cheers chris
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 24th Aug 2010 at 03:39
no m8 holes, no reference groove on the l/h end, splines a tad too square and not enouhg of a lead on the splines to make fitting the ARB end plate/levers on any easier?
if so then yeah sounds the same as all the ones i've seen, could be much better, especially when the same manufacturers turn out torsion bars.
Posted 24th Aug 2010 at 04:04
chrisd306
I will get pics tomorrow but 1 side looks hood then half way along it starts to get thinner and not shinney it's rough will take pics the Moro
& Audi Q5 S Line
Posted 24th Aug 2010 at 04:13
greenbelt
This is the only picture I have of mine but it is exactly as welshpug described.
Does the job though Thumbs up
Standard Black 6
Black HBSC6 Smoke
Posted 24th Aug 2010 at 04:34
Rich E Forum Admin
Pictures here
It's supposed to be thinner at one end than the other - that's why it's a hybrid size! The larger size is the original size of the bar and it is then machined to achieve the correct size and profile.
Posted 24th Aug 2010 at 04:36
chrisd306
Cheers Rich yes thats exactly how mine looks, just i thought it would of had a better finish thats all i know its a part thats never seen.
& Audi Q5 S Line
Posted 24th Aug 2010 at 04:57
ash
Six Addict
Chris I think it was me that sold it to you and it's a hybrid bar which means two sizes, one end is turned down so it fits through the trailing arm as rich said. Welshpug is correct the splines are a bit to square which means it needs a whack to fit but I've sold loads with no problems. The only thing to point out is Each end has a different number of splines so that you can have almost infinite adjustment of alignment from one lever end to the other. The simplest way is to gently fit each end using the floor to see when it lines up. If not rotate each end one spline and try again. 32 options I think. Then try it on you car before you knock an end on because the trailing arms may not be perfectly in line anyway. When you are sure it is in line make sure you fit the lever end on the fattest end of the bar first or you won't be able to fit it to the car!
Posted 24th Aug 2010 at 05:09
chrisd306
Cheers ash, you would of sold it to Craig (condieboy) as thats who i bought it off
& Audi Q5 S Line
Posted 24th Aug 2010 at 05:13
