Author Subject: focus RS brembo's
spiky
are they the same as any other brembo's?
is there a someone who makes a kit for these?
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 22nd Aug 2010 at 21:33
berger
They are the same family as the 406 Coupe/Alfa GTV/Fiat Coupe.
But the mounting lugs are different to the 406 ones, more like the Alfas iirc so you may have trouble making them fit.
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 22nd Aug 2010 at 23:36
mabgti
NV motors
yup... lug mounted but bolt centre dim are diff on all above.
think they were made for 324mm/28mm discs so the pad sweep aint ideal unless you hit that diam.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 22nd Aug 2010 at 23:49
spiky
Ok, will forget about them
MY YouTube Videos'
Posted 23rd Aug 2010 at 00:00
mabgti
NV motors
The focus rs discs are nice though same pcd and good offset.. couple with renault sport brembo's could be a nice setup!
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 23rd Aug 2010 at 00:41
spiky
will they fit under 15's? as i wont be going bigger than 15's
MY YouTube Videos'
Posted 23rd Aug 2010 at 01:46
tvrfan007
totally different profile to a 6 disc, can't see it fitting and am sure that Lotek found they twat the balljoint.
They all use the same pad btw.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 23rd Aug 2010 at 02:07
mabgti
NV motors
has a smaller centre bore easily machined out.. but yeh it runs a disc offset of about 53mmYes So could cause a clearance issue with the BJ..
I had 300mm focus ST discs on with no issues with custom brackets on cupra R calipersYes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 23rd Aug 2010 at 03:43
berger
ST170 discs that would be?
Are they not too thin at 24mm?
Posted 23rd Aug 2010 at 03:50
st225 I'd imagine being 300mm dia...
Posted 23rd Aug 2010 at 04:24
mabgti
NV motors
st170Yes 24mm more than good enough Yes
hispec used 24mm thick discs in their kitsSmile
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 23rd Aug 2010 at 04:59
Rich E Forum Admin
IIRC the Mk2 Focus uses 5 stud fitments
Posted 23rd Aug 2010 at 05:03
crikey, why the hell does an ST170 have brakes that big, theyre bloody slow Laugh my ass off
Posted 23rd Aug 2010 at 05:19
berger
Mmmmm how did they work out?
Can have the centre bore machined out no problems and making brackets to suit renaultsports should be easy.
Posted 23rd Aug 2010 at 21:48
rallyestyle
Just use the 406 V6 coupe discs with the renaultsports if you dont want to get ash's kit Yes
Just Drive It
Posted 23rd Aug 2010 at 21:59
mabgti
NV motors
as rich_w didYes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 23rd Aug 2010 at 22:06
berger
I was told they weren't much cop in the last thread where I asked about them due to the vane design?
Plus nobody has a drawing to make up some adaptors from, so I will need to have that done/design some anyway, so using a different disc is no trouble given that it will almost bolt straight on anyway with minor alteration.
Posted 24th Aug 2010 at 01:03
mabgti
NV motors
i have drawings... but will have to get a group buy sorted..
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 24th Aug 2010 at 05:37
rallyestyle
The ST170 discs wouldnt have a better vane design i dont think No Im not sure on the science behind it but you will need to be getting very serious about your brake setup to start taking vane design into consideration, if your at that point then it might be best to look at new setups from the big players like AP.
Just Drive It
Posted 24th Aug 2010 at 13:46
tvrfan007
The vane design wasn't in question, it was the vane interaction with the 306.
velar wrote:
I would avoid the 406 305mm discs.
I ran them on a few 406 track coupes(inc an ex btcc shell) and they overheat within a few laps( common on the 406 when tracked).
I replaced them with Focus RS discs and the overheating issue went away.
I think that due to the low offset, the root of the cooling vains are restricted(only about 5mm gap) and this prevents decent airflow through the discs.
The offset is also wrong for the 306 hub.
Not sure why Rich changed setups, maybe he found the same.
I'm Si btw Tee hee
Posted 24th Aug 2010 at 15:23
rallyestyle
I see, that might be the case on track but it could have possibly been cheap discs or something like that too. Im pretty sure the RS discs cannot be fitted to the 306, the V6 offset is by no means perfect but it can be fitted Smile
Just Drive It
Posted 24th Aug 2010 at 15:50
tvrfan007
RS discs hit the balljoint, i'm sure it was lotek did the checks. ST170 discs are a different profile though iirc (thinner by 4mm and narrower by 8mm) as used with a single piston sliding caliper. Smile
I'm Si btw Tee hee
Posted 24th Aug 2010 at 17:00
berger
The Focus RS disc is 52.7mm tall and 28mm thick.
The Focus ST 170 is 44.5mm tall and 24mm thick.
By comparison the GTI-6 disc is 27.2mm tall and 22mm thick.
Posted 24th Aug 2010 at 19:40
velar
These can be made to fit a 306 by using a 20mm or 25mm spacer inside the Focus RS disc, and then running Ford ET 32 or ET 38 wheels
Posted 9th Sep 2010 at 01:55
