displaying posts 26 to 44 of 44
Pages (2): 1 [2]
Author Subject: Good coilover kit?
honestly3k
Thanks Owain.
Its probably in the FAQ but its taken me till now to even realise the back is torsion bar and not spring, LOL
Ok i will probably do as you have done and get the front sorted pronto.
I think 40mm lowered at the front looks just right. And is it considered good for handling and comfort?
Im hearing Bilstein B8's and eibach springs being thrown around alot?
Wheres the cheapest place to get these parts - eurocarparts?
Posted 23rd Aug 2010 at 21:54
oecken
or you could buy my beam and brand new all new bearings seals etc powder coated and get the car that its fitted to free, bargain price at £1700 ONO lol Whistle
Posted 23rd Aug 2010 at 22:27
honestly3k
Haha, nice try! Big grin
Posted 23rd Aug 2010 at 22:34
oecken
LOL not even started to sell it yet anyways! i had coilovers on mine, Avo all round, front offside snapped a ring, so had to change them for fixed springs, got quoted £50 from Avo to replace the springs which wasnt bad, but cba so they will be going in the bin or on ebay lol
Posted 23rd Aug 2010 at 22:37
honestly3k
Avo not such a great kit then?
Laughable they are charging you to fix their w*nky spring which could have damaged your car quite badly! Wink
Posted 23rd Aug 2010 at 22:41
oecken
too be honest is wasnt the cheapest kit judging by the car history (i didnt fit them, came with the car)
they were quite old, and as people said above i dont think they ever got adjusted, probably siezed up then corroded Doh but i suppose thats why their money pits ...
Posted 23rd Aug 2010 at 22:48
Well this is another thing to consider - you could spend less money on a cheap setup that can break/corrode/disappoint or spend more upfront and have a kit you can enjoy properly then take off and sell on when you get rid of the car if you need the money back.
I think my KW kit is 40mm lowered at the front, and I think that looks spot on. Handling will be much improved, and with a lower car you can get away with 195/50/15 tyres, which seem to be significantly cheaper than the standard /55 profiles Smile
O.
Posted 24th Aug 2010 at 01:57
honestly3k
O.
Thanks again, have you lowered the back inline with the front? Did you use the same dampers as at the front?
And lastly do you have some pics of your car on 40mm? Im trying to decide between 30 or 40, then i need to decide on which bilsteins'. Eibachs will probably be the springs i get. Big grin
Posted 24th Aug 2010 at 02:09
Yeah I finally got round to doing the back, I bought another beam second hand, reconditioned and lowered it then put it on as a whole. And yes, I replaced the rear dampers with KW ones while I was there.
The only picture I've got at the moment is on my build thread at the bottom which is the car at Woodbridge. Bear in mind it's on a corner so it's a little lower than normal, but that's 40mm or thereabouts Smile
I wouldn't fuss too much about 30 or 40mm to be honest, the two sides of a car can differ by up to 10mm or so anyway. The rear can't be set to the millimetre either as it's defined by where the splines line up on the torsion bars. I bet if I go my car on a flat surface and measured the arch heights all round there'd be at least 10mm difference anyway...
Posted 24th Aug 2010 at 02:15
honestly3k
Post #35
I read somewhere that the splines are 15mm apart so if i was to lower the rear by 30mm (2 splines) and do the front 40mm, that would still maintain the natural stance of the car, i.e nose down slightly and arse up! LOL
Giving a good stance and hopefully improve the handling...?
Hopefully someone can confirm that!
Posted 24th Aug 2010 at 02:35
Post #36
No I don't think it's as large a gap as that, I think about 5mm steps or thereabouts. I may be wrong, it happens a lot Wink
Lowering a car will always improve the handling due to a lower centre of gravity, but cheap springs and dampers can ruin it again. Lower weight is one thing, you still need good dampers and springs to match else you'll have poor grip on bumpy surfaces at speed - it's down to your dampers and springs to make sure your wheels get back down to the floor after a bump in the road.
As ever, it's a compromise - softer dampers are more comfortable, harder ones make for a harsher ride but you'll have much better grip.
People tend to think of tyres when grip's concerned but I'd say it's actually *more* down to the suspension. My mate's evo felt crapyourpants unsafe on Tein's, yet stuck like shit to a blanket on KWs. It's about reading up, studying people's opinions and then going with it - don't be the guy who decides to try and be clever and go for something else, just to find someone else has trodden that world of pain before you Wink
Just to throw another spanner into the works, there is also no single answer to what you're after. What will you using the car for? Do you do trackdays, "fast road" or do you literally just want it lowered to impress the laydeez?
O.
Posted 24th Aug 2010 at 02:50
honestly3k
Post #37
Strictly road use, i want it to look better as standard height isnt great to be honest. Also want it to handle better than standard. Want it to be firm but not harsh.
Im going to need 2 front and 2 rear dampers then, 2 front springs that compliment the dampers well.
And then the torsion lowered at a later date with possible new perishable parts to make sure thats in good condition.
Ive read alot of threads now and im no clearer about what Bilstein dampers to go for. I understand Bilsteins are the damper to go for but which type..and why?!
And that Eibach springs compliment them well. So 40mm Eibachs are on the list. Its just the dampers im unsure about....
Posted 24th Aug 2010 at 03:00
Post #38
Righty ho, if you're just looking to lower it then yes, you're spot on. Fronts you'll be needing springs and dampers, rears just the dampers.
As for which ones though I won't be any good I'm afraid, I've only ever used KW on mine. It's a case of searching on here and reading pretty much every thread you find. Expect to lose at least 2-3 hours of your life Wink
I did have Eibach springs on my old car, and was very impressed by them.
Posted 24th Aug 2010 at 03:09
honestly3k
Post #39
Thanks for your time,
I understand B4's are standard and the same as genuine pug dampers. B6's are good for 30mm drops i think. B8's for big drops of 60mm or so....
Will keep reading. Sorry for the monumental thread size LOL
Posted 24th Aug 2010 at 03:18
Post #40
30 mm drop at the front, on standard dampers, with a 30mm drop and 21mm torsion bars from a 306 estate on the rear. You can upgrade the dampers later if you are flush, until then you will have a cheap, relatively easy to get setup that really will work. If you can combine it with some B8s up front and some 205 grpN tarmac rally dampers at the rear you will really have a very sensible setup that will eat up B road miles and still hold its own on a trackday.
Posted 24th Aug 2010 at 03:26
honestly3k
Post #41
So eibach 30mm springs are ok on standard dampers? That sorts the front.
How would i achieve the 30mm drop on the rear, just by lowering the torsion bar? In which case what do you mean by 21mm torsion bars from an estate?
Ty kind sir Smile
Posted 24th Aug 2010 at 03:33
Post #42
The car is too soft at the rear already, fitting harder, lower springs at the front is helpful to handling. But, you need to do the same at the rear to maintain balance. To that end fitting bigger diameter torsion bars will increase rear end stifness in line with the front so you don't end up with the car pitching up and down at the rear and reacting totally differently to bumps than the front of the car. In order to get a cohesive suspension package that works you must aproach it as a whole. As standard I think the 6 has 19 or 20mm bars, that extra mm or so seems like nothing but it actually makes something like a 25% increase in stifness (Phillip M will be along shortly to tell me to the nearest .000001 of a % how close my estimate was)
This was the exact setup I ran on my Rally for ages and it really was a very good setup for very little outlay. I think I got yhe bars for £120 (New, you could find second hand ones but I'm not patient) and I think I found some really decent Eibach 30mm drop springs for around £60 (Second hand of course, more like £100 new)
Uprate the dampers later when you can afford it, the car will not be drasticly under-damped with the above parts fitted and you will still have good compliance for wet grip and with uprated rear bars you can carry fat passengers and luggage in the boot without worrying about bottoming out on every bump and compression.
Posted 24th Aug 2010 at 03:48
honestly3k
Post #43
Great post. Thanks.
Currently i think it has 60mm lowering springs on standard dampers at the front which is horrible to say the least. Im told it has probably damanged the standard dampers on there with this sort of drop.
So i will have to find the cheapest place to sell new genuine pug dampers and then the 30mm lowering eibach springs. That will see me ok for now. Do you know any good sites that are reasonable value for money?
Thanks again
Posted 24th Aug 2010 at 03:54
Post #44
Keep and eye on the for sale section on here, plenty of people have upgraded to coilies so there are often used dampers up for grabs. Place a request in the Wanted section too for more chance of success. As for new, Euro Car Parts, GSF, etc. Do a few comparrisons against each other.
Posted 24th Aug 2010 at 03:59
Pages (2): 1 [2]
