Author Subject: Weird clocks issue
smegal
I got into my car to go to work and all my gauges except my temp gauge aren't working.
Does anyone know of a common problem or am I going to be head scratching tomorrow?
Ex SC-6
Now in a Megane R26
Posted 19th Aug 2010 at 02:11
smegal
That was easy. I pulled the shunt fuse out and left it while I checked all the fuses, put it back in and all was fine.
Ex SC-6
Now in a Megane R26
Posted 19th Aug 2010 at 19:34
oecken
is that not just the "french charm" shining through smeg? Razz
Posted 19th Aug 2010 at 22:31
smegal
I did try hitting the dash. That usually fixes things like that.
Ex SC-6
Now in a Megane R26
Posted 19th Aug 2010 at 22:35
funny you say this as i had a total dash failure but whilst sat in a traffic jam on the M56 about a month ago. i put my chair back to the furhest position and smashed the corner of the dash near the driver side corner with my heel and it all came back to life Laugh my ass off
i also had dash failure when i shorted my clock out. i 5a fuse which controls the ignition and all sorts had gone. simples
Posted 19th Aug 2010 at 23:36
monkgti
my fuel guage done that a few times, it wouldnt rise and then by accident i fixed it by taking out the fuse to check it and when i put it back in it worked Crazy
IF YOU CAN READ THIS IM STILL IN 5TH!!!
Posted 25th Aug 2010 at 00:35
tvrfan007
Fecks sake mine is doing exactly this at the minute. Tried the shunt fuse and it's not playing ball.
Had each and every fuse out of the box inside the car, including the shunt. Had the battery on and off a few times, only the temp gauge is playing ball. Had all the earths off and cleaned them up but need to check them for continuity next.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 18th Oct 2012 at 17:53
ian7675
Techno Viking
Off topic, how's it being home now?
Less than 24 hours to go!
Posted 18th Oct 2012 at 19:53
Have you actually checked all the fuses electrically?
Also, is it ONLY the temp gauge which is working and the complete rest of the dash isn't?
Posted 18th Oct 2012 at 20:43
tvrfan007
Enjoying it! Haven't been back to work yet though, still on holidays Big grin Gonna spend the day on the Rallye tomorrow, just want to sort these damned clocks!
I'm Si btw Tee hee
Posted 18th Oct 2012 at 20:44
Moved to Electrical. Smile
Posted 20th Oct 2012 at 18:07
tvrfan007
Hi Stan.
The temp gauge moves off the bottom to somewhere under 70, you can see it move.
Oil level and temparature not working.
Speedo - stuck at 70, or wherever you push it to.
Revs - Stuck at 4500, or wherever you push it to
Fuel gauge - stuck at the bottom.
Spare set of clocks still the same. Found a loose earth today and changed it but to no joy. Also noticed I have no time on the clock by the cigarette lighter.
Haven't electrically checked each fuse, but now you've mentioned it I shall do. Shunt fuse has been out, but nothing seems to die/happen as/when you pull it out and re-insert. Tried waiting a minute, tried ignition on, ignition off etc but nothing seems to happen?
Clocks seen working here prior to engine swap:
Clocks did this on first start after engine swap:
Have I wired something back to front maybe? Like the alternator?
I'm Si btw Tee hee
Posted 20th Oct 2012 at 18:27
tvrfan007
I get dash lights by the way, and all the warning lamps operate on the clocks, but I get no odometer display.
I'm Si btw Tee hee
Posted 20th Oct 2012 at 18:43
Hmm
It's a tricky one. To my mind it has to be either a dodgy connection or a blown fuse. Although a blown fuse would not operate the dash at all. How long ago was the engine swap?
Posted 21st Oct 2012 at 00:04
tvrfan007
Was changed last year, but I went to South Africa so it hasn't turned a wheel yet under its own power.
I'm Si btw Tee hee
Posted 21st Oct 2012 at 00:12
In that case I would disconnect, clean up and reconnect the two large round multiplugs on the n/s inner wing where the engine loom joins the car loom. Yes
Dodgy connections here have been known to cause all sorts of issues and I'm gathering that these were messed with when changing the lump over. Wink
Posted 21st Oct 2012 at 10:21
checked the power connections on the main fusebox?
Posted 21st Oct 2012 at 10:45
tvrfan007
Funnily enough I did that yesterday afternoon whilst following the loom, and it all looked healthy! Cleaned for the sake of it and reattached.
Welshpug, I shall do that.
Gonna get my mate who's an electrical engineer to come have a look see for me but keep the suggestions coming. Smile
I'm Si btw Tee hee
Posted 21st Oct 2012 at 18:28
berger
I can't believe you haven't managed to solve this yet, what a ballache.
Can you get behind the dash easily to check you are getting continuity through the wires to the clocks?
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 24th Oct 2012 at 07:52
tvrfan007
I'm away again all week so won't be on it till Sunday earliest. Looking at the wiring diagrams it seems the three that don't work all go through the instrumentation control module, so perhaps it is missing a feed.
Need to see the car and bay wiring loom diagrams
I'm Si btw Tee hee
Posted 24th Oct 2012 at 08:58
I'm still thinking faulty fuse or fuse holder. Yes
Posted 24th Oct 2012 at 12:53
tvrfan007
Thanks Stan, I'll suss it but electrics are but my forte. I hope to be on it this weekend. Smile
I'm Si btw Tee hee
Posted 24th Oct 2012 at 16:33
I'll have a look through some wiring diagrams in a bit and see if I can trace a common factor for all of these failures...Thumbs up
Posted 24th Oct 2012 at 19:04
tvrfan007
Thanks for the patience with this Stan.
I might be off on business again next week so might have to spend the time with the mrs, given i've only just come back!!!!!!
I'm Si btw Tee hee
Posted 26th Oct 2012 at 13:45
LOL
No worries, I will have access to the drawings tomorrow so will see what I can find. Thumbs up
Posted 27th Oct 2012 at 19:04
