displaying posts 26 to 50 of 227
Pages (10): 1 [2] 3 .. last
Author Subject: High Boost Supercharged Rallye
ben306
Spot on. What did you use to treat the rust in the engine bay.
Going to be dropping the engine out of mine in the next few weeks while I rebuild up a new bottom end, thinking of sorting it out similar to you.
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 22nd Mar 2011 at 16:31
russbez
thanks folks, yeh as Mat has been saying since i done all this iv been having issues with my rear beam. ill post more once i get to pictures.
Ben, its Bilt Hamber Deox-Gel
back in August 2010 i just used Bilt Hamber Deox-Gel, pressure washed the stuff off outside the garage, then reapplied a few times. Then went straight in with the Zinc antirust primer ; seems to be ok, few spots of discolouration along joints and box section i couldnt get into to derust.
This year iv done rear end with Bilt Hamber Deox-Gel, then Bilt Hamber Hydrate 80 then the isopon zinc 182 anti rust primer just to be sure LOL
My Rallye project thread
Posted 22nd Mar 2011 at 17:03
russbez
[POST 8]
Mid January got slowly started with derusting:
Car elevated using axel stands, took a few pictures before I started anything major.
Underseal needed removed and rear axel too, didn’t get this done straight away
Had 4 inch grinder with wire brush on standby, along with small handheld air grinder and various attachments, also used compressed air for blastings loose bits off. These first pictures were after a wee poke about with wire brush. Really looked bad...
This bracket got damaged and bent pretty badly 2/3 years ago when a taxi decided to try and push me out a junction. It needed straightened to say least
Exhaust heat shield before it got sand blasted
Drivers side rear arch had lots of underseal, which required lots of attention with 4 inch grinder with wire buff disk on it
Passenger side rear arch
Planning getting spare wheel cage sand blasted soon its still to be fixed
This was the thread that I fixed with the Recoil kit:
From : January 2011, changed links due to Photobucket fail
Posted 12th Jul 2017 at 17:23
russbez
Started using Bilt Hamber Deox-Gel, then blasted off with pressure washer, think these pictures are after 1 application, still haven’t got round to taking underseal off or get my mates round to help take rear beam off
edit: did have pictures of car after 3 or 4 seems to hav misplaced them.
Posted 8th Jul 2011 at 18:00
russbez
After the above pictures I got to work with removing excess rust and underseal
Took a 4 inch grinder with wire brush disc attachment to 90% of underneath of car, the rest I tried my best to use a small air grinder with different wire brush attachments.
Will try and remember where the pictures have got to, but here is the next step I took
Can see the rear beam and most of the underseal has been removed by here
Hydrate 80 doing its stuff:
Weblink : Bilt Hamber Hydrate 80
Done two coats of this stuff, you can probably see that I missed a few patches there
Next step was anti rust zinc primer...
Posted 8th Jul 2011 at 18:02
russbez
Posted 12th Jul 2011 at 16:38
russbez
Next bunch of pictures are after I had painted a few coats of white gloss spray tins, didn’t bother with buying Bianca white with rear... no one will see it or notice LOL
Last 6 pictures are actually after I lacquered, just looks the same
[pictures to follow]
Posted 22nd Mar 2011 at 21:28
russbez
Posted 12th Jul 2011 at 16:41
Christ she was rusty!Shock
Not picking at your work but you should have taken the rear bump stops and cups offWink
Would have been plenty of rust under there for sure that needs treatingSad
Posted 23rd Mar 2011 at 02:09
dans16
Post #35
looking good mate.
more work than you first thought? i no i thought that after i stared but mines slowly coming along Smile
234 BHP TB RALLYE
¼ mile 13.9
MY PROJECT THREAD
Posted 23rd Mar 2011 at 03:19
russbez
Post #36
Na thats fair enough coskev, but I couldn’t get it off Dry
the recess had a few applications of Bilt hamber gel, pressure washed, air gun was poked in that we recess blew lots of dirt/rust out of it – done that a few times, dried with heater and heat gun. Then the Hydrate 80 everywhere...
Yeh just a bit Dan, doesn’t help when girl friend keeps asking “when will you be done” towards the end of it all when people asked me that question it made my blood boil…. FCUK OFF how long is a piece of string?
Anyway more pictures to follow, Davey at Sound of Silence has since rewelded the outlet of my supercharger then we had it on rolling road. Boost leak for now is fixed, although it seems to be intermittent, perhaps during hot weather while stuck in traffic it might resurface.
Posted 13th Apr 2011 at 19:52
russbez
Post #37
few of these are after lacquer, they might be mixed up Whistle
russbez
Post #38
****POST 39****
Mates stuck this to front of car…. garage mascot bird with squint boobs Wink
Back to work.... old mounts off
Old Rear beam back on, solid mounts fitted too. (April 2010 : Beam soon to be removed and replaced, not 100% about solid mounts either, roads up here are total w*nk)
Heat shield sand blasted, primed and sprayed with galv spray
Spare wheel cage sand blasted, primed and sprayed with galv spray
Fuel tank brackets got similar treatment, fitted here, copper seal everywhere Smile
beam more bits connected up
Where old and new meets
Exhaust and spare wheel refitted
An attempt to stop me getting static shocks off the car Unsure basically old ones were long gone
Wheels in dire need of clean, wonder wheels to the rescue
Made it down to Falkirk in one piece
More pictures of the meet in our Meets section.
SoS Rolling Road day 27 March 2011
Posted 8th Jul 2011 at 18:10
russbez
Post #39
Attempting to source refurbished rear beam now, old one is making lots of noise Sad
also ordered Lemforder rear beam mounts, not sure if i will be keeping solid mounts. Roads around here are far too poor to enjoy these.
Will be replacing rear beam soon as the drivers side of the beam is making loud clunking noises, not helped by solid mounts and unavoidable potholes Dry
Posted 20th Apr 2011 at 17:41
eddy_gti6
Post #40
Looking good russ. are they solid rubber axle mounts or metal ones just painted black?
Whats next on your list before august meet?
Posted 10th Jun 2011 at 07:03
spiky
Post #41
good power there Big grin
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 10th Jun 2011 at 14:25
russbez
Post #42
cheers folks
that ones pictured there are Birks solid ones painted black. They are nice and tight but couldnt really make a fair assessment with them when my rear beam was soo f*cked
bought Lemforder OE rubber ones to replace the solid ones, roads are too bad up here
yep I should be at next meet long as im not on holiday which I think I am at end of August, have to keep female happy LOL
Posted 14th Jun 2011 at 16:17
russbez
Post #43
Note to self.... Never change the names of albums in Photobucket = fail Doh
more work done past few weeks
Posted 8th Jul 2011 at 18:12
russbez
Post #44
Took the rear beam off at the start of June, took it to a local engineering firm who refurbished my beam. Replaced bearings, shafts etc.
Also took this as an opportunity to get 21mm Torsion Bars, Ash’s Hybrid Rear Anti Roll Bars and install a set of standard Lemforder rear mounts.
Solid mounts I had are a wee bit too harsh for my back roads.
Beam on with help from a friend or two
Still putting on rear hubs, bearings packed with appropriate grease.
And to my joy they hadn’t set the height correctly
(new torsion bars and thicker arb aside, they were only 80mm higher than I gave them the beam originally Blink)
I had asked them to raise it 10mm
Next step was to sort the height.
For the eagle eyed..... yes the Engineer firm have switched the arms about and now the ABS sensors are facing the wrong way and now no longer fit in the holders ; in their defence they did ask for the beam to be without sensors..... but still Whistle
Posted 8th Jul 2011 at 18:58
berger
Post #45
It's very blue...
Not think to mask off all the important parts and mating surfaces?
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 8th Jul 2011 at 19:48
russbez
Post #46
it was going to be a manky green colour so blue it was, dont see rear beam anyway? Dunno
sprayed on with 2 pac commercial paint, surprising easy to chip - not really an issue as paint was just to help it reduce corrosion. Do plan on touching missed/damaged bits up
beam was already built up before i got it painted? it came red etch primed, not ideal i know
parts such as the shaft the rear wheel bearings slide onto had copper grease all over them, the paint wiped off
but i did have to run a tap through the threads
some of the red paint that looks like rust is actually red etch primer
Posted 8th Jul 2011 at 20:40
russbez
Post #47
Next step unfortunately I had to lower the car again, originally it was too low… nearer -50/60mm. Got it back from Engineers way too high.
Started by stripping shocks etc off car to take measurement of what car was currently at.
Using a home made slide hammer managed to get the bars out
Picture of slide hammer, ARB and one of my torsion bars
One of the torsion bars back in
Back together….
Reasonably happy with height ; one side is off less than 5mm, from what iv read that isn’t much.
Posted 8th Jul 2011 at 20:33
luke306rallye
Post #48
The size of that slide hammer! LOL
Posted 9th Jul 2011 at 00:27
thelegendofando
Post #49
Shiny! Big grin
205 GTi6 - work in progress
Posted 9th Jul 2011 at 04:22
russbez
Post #50
yeh home made slide hammer, effortless ftw
edit : had to update a heap of previous pictures as links no longer worked (my fault)
Posted 12th Jul 2011 at 16:48
