| Author | Subject: clutch pressure plate |
papa
Newbie Location: ayr Registered: 27 Jul 2010 Posts: 4 Status: Offline |
Bolts on pressure plate to flywheel siezed, any ideas. |
use bigger bar ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
greenbelt
Seasoned Pro Location: How's Life In London? Registered: 23 Apr 2006 Posts: 1,961 Status: Offline |
Does the flywheel need to be locked to undo the bolts and if so, what do you use?________________________________________ Standard Black 6Black HBSC6 |
I just use a draper Allen key bit from the set and a 3/8 ratchet, if needed I use a big screwdriver to hold the flywheel.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
greenbelt
Cheers ________________________________________ Standard Black 6Black HBSC6 |
welshpug! wrote: I just use a draper Allen key bit from the set and a 3/8 ratchet, if needed I use a big screwdriver to hold the flywheel. Teamwork makes the dream work |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
Have you tried an Impact driver? that should get them to move. If not Just grind or drill the heads off then the threads will just screw out as the pressure on them is gone (we had to do this on a few of Daveyboys ones) |
papa
Thanks for your suggestions but my final solution was a bit unorthadox. On two of the bolts the torx bit would not hold and was starting to chew the nuts. I used a scissor jack against the inside wing applying pressure to the ratchet and torx bit and hey presto! |
err, all I've ever seen used is a 6mm allen or a 13mm AF headed bolt!so I may not be surprised at all that a Torx bit slipped ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
papa
Well I'm not surprised that your not surprised but suprise, suprise it worked. |
