Author Subject: leeking rocker cover
spaniel
i have had the head gasket done a while ago and since then i have had a leak from the rocker cover, when i took it off the original grey gasket had come away in one corner.
i took it off and re-sealed it with some silicone gasket maker but it is still leaking a bit. i have talked to pug and they have told me this is the stuff to use.
it doesn't leak alot but its from the exhuast cam and drips straight onto the manifold and smoke like a b*tch.
what do i do next??
Posted 14th Aug 2010 at 00:28
hanpug25
Afraid its sealant is the only option fella, unless you buy a good 2nd hand one.
I have one if your interested Whistle
Ad.
Passat B5.5 TDi estate (174bhp, 260 lbs/ft)
Posted 16th Aug 2010 at 00:24
leaking mate not the veg
Posted 16th Aug 2010 at 00:28
miles
Remove it, clean it and re-seal it, I use Wurth RTV and never had issue with it for over 5 years
Very common on all the later Pug engine's
www.pugracing.com
Posted 16th Aug 2010 at 02:35
bradawl12
dont worry, i had the same problem. it went back to the garage 5 times till it got sealed. they had to use a high temperature sealent. because of the heat from the mani, it kept leaking. same deal as you, onto the mani and smokin like fcuk!
TEAM: bottom end knock!!
Posted 16th Aug 2010 at 23:38
spaniel
yeah mate i been using whinns sealent goes up to 250 degrees apparently. all gone tits up now though one of the bolts snapped and then the 10mm bolt which goes near the belt has stripped the thread from the bit that holds the cam in place. so looks like i got some more work. anyone got one of thease i need it asap???
Posted 16th Aug 2010 at 23:43
