Author Subject: Ratte at 3100 RPM
gti306ftw
When the cars in gear at 3000 odd revs i get a rattling noise from the CAT area.
I have just had a new CAT and silencer fitted, but the rattle occured before this. it only happens when im in gear! frustrating when your trying to point it out to the bloke at the Exhaust place! Dry anyone know what this might be ? it definatly sounds external.. Heatshield perhaps ?
Posted 13th Aug 2010 at 17:34
blaze wip
Heat shield or engine mount maybe? Dunno
EDIT: Engine mount would be more like a droning vibration than a rattle so probably the heatshield
mechanical_repairs wrote:
i feel like giving her a good dry bumming session.
Posted 13th Aug 2010 at 17:37
birk
As blaze said, i'd place my bets on it been the manifold heatsheild or the engine mount been loose.
Both came loose on my a few weeks back, quick tighten up and they were fine.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 13th Aug 2010 at 17:54
had the same prob on my black 6 a few months back. One of the 4 manifold heat shield bolts had come loose. And of corse is was the very awkward one on the lower drivers side...
Posted 13th Aug 2010 at 18:08
beez_neez_gt
This happened to me and i found out it was the catalytic converter, the previous owner bought an aftermarket Jobie rubbish, the seal had come loose so the inner part of it was moving around making a rattle at those revs.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 13th Aug 2010 at 20:07
ablister
double check lambda probe is tight
306 rallye, Richard Longman engine
rc10gt
Posted 13th Aug 2010 at 23:10
gti306ftw
Thanks for the info! ill take all this on board when I get under the car! as birk said most likely something to do with the heat shield or the engine bolts. I had a new sportier CAT put in recently so it cant be that.
Posted 13th Aug 2010 at 23:50
kit
I am getting this but not when I rev the car. It's evident when I turn the ignition on/off when the car is warm. Could this be down to the cat?
Sounds like it's coming from the gear stick area.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 14th Aug 2010 at 04:42
beez_neez_gt
Its the cat area for sure, could be the heat shield most likely.
Pug fee`ver,
Posted 14th Aug 2010 at 04:48
willygti
Timing belt too lose? Remove the belt cover asap and give it a check!
Team Ducati 748
2003 Subaru Impreza STi
Posted 14th Aug 2010 at 14:57
chas
Whilst it could be the cat, I believe that a shot exhaust gasket at the Manifold/cat join can cause this (it did for me anyway).
Get a genuine Pug fitting kit (about £18), the others seem to come with the wrong nuts and no spacers etc. and generally can sometimes be more pain that they are worth for the reduced price. If this wasn't changed when the cat was changed, I would almost guarantee that the gasket is causing your rattling.
Ex Owner of 2000 Phase 3 306 GTi 6 China Blue - You shall be missed
1974 Triumph Stag
1989 Peugeot 205 GTi 1.6
2003 Alfa Romeo 147 JTD Lusso
2005 Mondeo Ghia X 3.0 Estate LPG
Posted 10th Sep 2010 at 04:00
justinaccurate
Do you have aftermarket gear linkages? Mine vibrated at certain revs in every gear Dunno
Posted 10th Sep 2010 at 12:30
