Author Subject: Help needed with Omex 600
roberts_306
I have just tried to upload a map file onto my Omex 600 ECU, when using the Map 3000 software its says the ECU is offline, spoke to Omex they said its probably the lead.
Omex said try using different USB ports which I did still no luck.
What leads have you been using was considering a RS232 to RS232 lead?
Any comments or suggestions please!
www.pugsport-racing.co.uk
Posted 13th Aug 2010 at 12:16
You have got a permanent 12 volt feed coming in on the red wire when the ignition is in the run position have'nt you? If you pick a wrong wire to use as your live feed it can be live when you turn the ignition to the first position but then go when you turn the key further to the crank position.
Posted 13th Aug 2010 at 13:31
roberts_306
The wiring is correct as the ecu is getting power as the fuel pump is starting
Posted 13th Aug 2010 at 15:02
If it says its offline its probably not getting power. I'd re-check that supply if Im were you. By the way I have that map now if you still need it?
Posted 13th Aug 2010 at 16:53
mabgti
NV motors
if its getting power and priming.. the omex should be ok..
are you using a serial>usb convertor?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 13th Aug 2010 at 19:06
Carl Chambers
Fuel pump primes when ignition is turned on and also runs when cranking, plus the rev counter jumps so Omex has got power, the problem seems to be the lead or the lap top!
Ideally need a lap top with a serial port but these are hard to find, so using the usb port, I have searched online and found loads of people having problems but no real way round it other than finding a old lap top with a serial port? any one have any ideas? anyone done it using the usb port?
Computer knows the ECU is connected and the lead is in but it says ECU is always offline.
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
Posted 14th Aug 2010 at 01:48
rcarney1989
plug a normal pc up next to the car LOL jokes
but get a good expensive serial to usb or even better a serial t e/sata
Team:Kuwait Working :<
6 is in the uk in my garage :<
but shes going high boost when i return to the uk Big grin
Posted 14th Aug 2010 at 02:00
miles
Easy fix this one, You need to find a suitable PCIMA card, Pot luck really so buy a few
I'm surprized Omex didn;t say this as it quite common knowledge
www.pugracing.com
Posted 14th Aug 2010 at 04:42
mabgti
NV motors
huh?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 16th Aug 2010 at 23:54
roberts_306
Now sorted
Posted 17th Aug 2010 at 00:16
Carl Chambers
mabgti wrote:
huh?
thats what I thought?!
Anyway got an old computer with a serial port and got the correct lead (after trying 4 places!Crazy )
and the base map went straight on no problem!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 17th Aug 2010 at 00:19
mabgti
NV motors
as said previously usb>serial convertors are SHITE... i've bricked 3 VAG ecu's with em! No more... fresh toughbook for all my remapping nowSmug
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 17th Aug 2010 at 03:12
miles
Whats not to understand about a PCIMA card with a RS232 port on, as Mabgti's said USB ones are ****
www.pugracing.com
Posted 17th Aug 2010 at 03:40
chris with a pug
I disagree with that, I use a USB to serial converter almost everyday to configure routers. They work fine never had a problem. Laptops with serial ports on are a dying breed
Posted 17th Aug 2010 at 03:49
Carl Chambers
depends if you know what one of those is!!
engines good, computers notLOL
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 17th Aug 2010 at 03:58
I'll be sending Dave my map tomorrow lunchtime Smile
Posted 17th Aug 2010 at 04:10
alastairh
Agreed. I use to use them all the time. I now prefere the spanners though!
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 17th Aug 2010 at 04:11
The Prolific chip'd USB>Serial converters are pretty reliable, I use those all the time with no problems.
Posted 17th Aug 2010 at 04:14
mabgti
NV motors
chris.. usb to serial convertors use their own drivers which dont allow ECU upload baud rates... some can get away with it but most dont.. obviously a PCMCIA card convertor does away with drivers as it has designated port adresses so is ideal if you have oneYes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 17th Aug 2010 at 04:23
chris with a pug
I can change the Baud raitings on mine.
Posted 17th Aug 2010 at 04:38
Same here?
It should install as a normal comm port just running through the driver as a translator program, so if you go to comm settings you can alter as per normal.
Posted 17th Aug 2010 at 04:40
chris with a pug
phillipm wrote:
Same here?
Exscatly. I need to change mine for different applications
Posted 17th Aug 2010 at 04:46
miles
or buy a Emerald with a USB port, LOL, shame the software isn't available yet thou!!
But I;ve never had any luck with USB thing'e's, maybe the £3.00 I spent on it may had been the problem with my XP lapo top
www.pugracing.com
Posted 17th Aug 2010 at 05:30
Denis
There are two main chips for the USB to RS232 adapters: Prolific and FTDI.
In my experience most cheap dongles have Prolific chip and do not work properly. On the other hand, FTDI works every single time.
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 17th Aug 2010 at 06:02
mabgti
NV motors
prolific is all ive used... henceLOL
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 18th Aug 2010 at 04:12
