displaying posts 26 to 37 of 37
Pages (2): 1 [2]
Author Subject: Strut brace pics and infos
lotek
STOP!
TAKE THE BRACE OFF AND THE WASHERS NOW!!!
Take the plates off aswell, they do nothing to strengthen unless welded on No
Take it all off and start again!, JUST using the strut brace. Yes
/thread
Posted 29th Oct 2010 at 18:27
karazu
That metal plate is welded... =D
Posted 29th Oct 2010 at 18:59
mr swampy s16
**BAD SELLER**
hmm thatis odd!!
but dont run the brace like that!
you will do more harm than good.
you now all the forces tranmitted through the suspension focused on the three points of the bolts, rather than being spread out!!!
how long are the bolts you have in now??
Posted 29th Oct 2010 at 19:16
lotek
x2 take the washers out Yes
Posted 29th Oct 2010 at 19:23
karazu
30MM 10.9
mr swampy s16
**BAD SELLER**
they dont need to be any where near that length even with those plates in place!!
use 25mm bolts and all will be fine!!!
Posted 29th Oct 2010 at 19:25
karazu
25 dont fit!!!
because of that another metal plate that the cars in brazil have!
Posted 29th Oct 2010 at 19:29
mr swampy s16
**BAD SELLER**
how thick are the plates?
if a 25 is too short and a 30 is too lonh with out the washer thats its connecting the spring pan then you have problems!!
as there is no way that plate and the strutbrace plus washers have added a whole 1cm to the thickness of the area!!
Posted 29th Oct 2010 at 19:34
davedgti6
I don't get this surely if the bolts are too long just put washers under the head of the bolt?, which will shorten the length of thread between the strut brace and the top mount?, or cut the bolts?
Posted 29th Oct 2010 at 22:57
karazu
Post #35
I took the washers out... I just got to enlarg one of the 3 places to put the bolts... doing that.. the bolt got very good in place!!!
Thanks!!!
Posted 31st Oct 2010 at 00:03
karazu
Post #36
Well.. just to show... I enlarge 2 of the 3 holes of the strut brace!
And I change the bolts... and no washes...
and get like that! I liked very much the result
Posted 3rd Nov 2010 at 16:39
mr swampy s16
**BAD SELLER**
Post #37
You should still have washers under the head of the bolts
Posted 3rd Nov 2010 at 17:29
Pages (2): 1 [2]
