chris
| Author | Subject: Cylinder head removal |
kriz5176
Newbie Location: preston Registered: 06 Aug 2010 Posts: 28 Status: Offline |
Having looked at all the threads on removing the cylinder head, there seems to be different opinions on whether to leave the exhaust manifold on or off.The manual in FAQ says leave it on and use an engine hoist to get it out. Is an engine hoist a necessity or can it be manhandled out. My concern is catching the valves on removal or more importantly when putting it back. ________________________________________ chris |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
must remove ex manifold in the car, the head will not come out without a massive struggle with the ex manifold left on, if you do attempt leaving it on you will have to undo loads more and it is going to have to be removed on the bench anyway |
kriz5176
If it has to come out in the car - How on earth do you get to the nuts holding it on. The manual says hoist the lot out after lowering the engine a bit.________________________________________ chris |
Its a f*cker to get to the bolts some can be got from under the car the others from the top you kind of need to kneel on the engine if that makes sense ? |
the only one I found difficult was one that had rounded off ![]() I used a snapon 3/8 ratchet and 6 sided socket. did all of them from the top. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rallyeash
fun and games undoing them manifold bolts, some from the top kneeling on the engine with your head burried down by the bulkhead others underneath with extension bars... ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Rachet ring spanner from the top will remove all exhaust mani bolts and the head will come off, trust me i've just done it on my drive its not that difficult at all!, Just make sure you remove the exhaust cam cover and heat shield, it makes access easier! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
kriz5176
Thanks for all the replies. Off in the car it is then. Have to get a ratchet ring spanner now. Do i remember reading somewhere that it is a 13mm?________________________________________ chris |
stan_306gti6
Yes, 13mm....________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
jeffers
It is, halfords do a professional set (lifetime guarantee) for about £40 for 10-19mm Well worth it imo! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
kriz5176
Thanks for your help. I'll let you know how I get on, and no doubt want more help________________________________________ chris |
joevts
Senior User Location: barnsley Registered: 21 May 2008 Posts: 608 Status: Offline |
jeffers wrote: It is, halfords do a professional set (lifetime guarantee) for about £40 for 10-19mm Well worth it imo! or about £12 for the 13mm on its own if you're a tight git like me |
jeffers
joevts wrote: jeffers wrote: It is, halfords do a professional set (lifetime guarantee) for about £40 for 10-19mm Well worth it imo! or about £12 for the 13mm on its own if you're a tight git like me ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
mikebee
Regular Location: Northampton Registered: 17 Aug 2010 Posts: 122 Status: Offline |
Sorry to drag up an old thread. Will be taking the head off mine next weekend. It says in the Haynes book of lies to be very careful removing the head due to the wet liners.Is there anything else like this I need to be wary of? Good tips of getting the exhaust manifold off btw, makes this place massively useful! |
wet liners is the alloy block, you've been reading the wrong section ![]() the main point you have to be very careful of is not knocking any of the valves on the block as you lift off the head, it weighs about 30 kilos so best to have some assistance. have some card and a clean space to put the head down on its side, not on its face. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mikebee
welshpug! wrote: wet liners is the alloy block, you've been reading the wrong section ![]() Oops |
