Author Subject: Wandering...
bluesixxer
Is it a common thing for these 6's to be heavily influenced by white lines, uneven tarmac, ruts n the like, on my local roads the volvo i had before was never bothered by it, but this thing really pulls at the steering wheel, even just cruisin, if it finds a line u better hold on... The car has had new front wishbones, ball joints, drop links... the car is resonably well behaved on flat roads... The rear axle is startin to knock abit these days while brakin hard... The car is running original height, dampers etc... Any suggestions would be welcome... cheers watto...
Posted 10th Aug 2010 at 03:10
When was the tracking last done?
Posted 10th Aug 2010 at 03:12
bluesixxer
To be honest mate, the tracking does want resetting, i had the car tracked up when i bought it cos it was scrubbing tyres slightly, then i changed the wishbones and now it is slightly off centre... it has always wandered though, but that could hav been the bushes...
Posted 10th Aug 2010 at 03:17
What size wheels / tyres / make of tyres / pressures?
Could be beam bearings/mounts or P bushes.
Posted 10th Aug 2010 at 03:26
lwgti-6
Just grip the steering wheel tighter LOL....Thats my cure anyway Smile
Did you check the hub carrier for ovalisation around the ball joint area? Thats what happened to mine.
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 10th Aug 2010 at 03:29
bluesixxer
adam b...
yeah mate, standard cyclones, newish tyres, would a mis-matched pair make that much difference??? got Kumho n Toyo... pressures about 35psi...
Posted 10th Aug 2010 at 03:37
bluesixxer
Ovalisation?! um, summat for the weekend... will investigate... cheers...
Posted 10th Aug 2010 at 03:34
Never a good idea to mismatch them but I realise its not that easy. Is it the front wandering or the back?
Jack up each corner and see if you can make anything move. Check the hub pinch bolts are ok too as said above. Oh could be a top mount on the front too or possibly a snapped spring.
Posted 10th Aug 2010 at 03:48
smegal
With Rollerbearing bushes theese cars can be quite noticeable at tramlining.
Ex SC-6
Now in a Megane R26
Posted 10th Aug 2010 at 04:34
Mine's not bad on the rose joints tbh, it does occasionally have a squirm over catseyes/lines but nothing more than a twitch, even with the fast rack on, although I have lifted the rack slightly.
Posted 10th Aug 2010 at 06:30
