Author Subject: Unusual suspesion question - I need to Lift it
gtylerroberts@manx.net
I need to lift my 6 for forest rally- I have coilovers on the front so that is sorted - But is there a way of lifting the rear?
Posted 8th Aug 2010 at 17:24
Just for ground clearance like the front, or do you want more travel too?
If it's just for clearance then the easy way is to put a spacer under the rear beam mountings and the bumpstops.
You can wind the torsion bars around but you risk twisting them with extra travel and the shock loadings from a forest event.
Posted 8th Aug 2010 at 17:39
Ground clearance was the first priority - but if we can gain more travel as well that would be great - has anyone done this before and posted up a thread?
Posted 8th Aug 2010 at 17:41
What size torsion bars are you running?
The smaller bars can cope with more twist than the larger ones, however, I think going by rule of thumb on torsion bars you'd be OK with around an inch more on standard bars without much trouble, 45* of twist should be fine, but you will fatigue them over time at that.
Finding some more travel out of the damper will be the trick.
Posted 8th Aug 2010 at 18:32
Thanks Philip - is it easy to twist the bars? - I will check the bar size and come back
Posted 8th Aug 2010 at 19:01
Just have to knock them out and adjust the ride height as you would when lowering the car (guide in FAQ if you've never done it) - but obviously the other way around.
Posted 8th Aug 2010 at 19:02
they're under some preload as standard at 330mm between damper eye bolts (20mm bars) I think the bolts don't go in till they're at 320 or so, which is nearly 30mm in ride height.
Posted 8th Aug 2010 at 20:04
Yeah, hence needing to sort something out with the damper to get any extra travel.
Posted 8th Aug 2010 at 21:00
Thanks guys - you knowledge is priceless
Posted 9th Aug 2010 at 01:40
