Author Subject: Old Engine Out, New Engine In-Wont Run???
infosellerfsmail
Took the old engine out of the 6 over the weekend. Bought a replacement block and swapped everything over. I put the new engine back in with all current ancilleries, loom etc and now the car turns over and won't start.
The fuel pump isn't priming and the headlights start flashing after a while.
The car was sat for 8 months doing nothing at all and the battery in both the car and the key were removed. Does this mean that the key has lost its code therefore the car's immobilisor is stopping the pump from working??
Hopefully someone can help as slowly loosing my rag with it now!
Surely the pump should make a short noise when the ignition is switched on???
Josh
Posted 2nd Aug 2010 at 04:42
rich-6
Is the battery charged up? The alarm is going off but your sirens funked!
Cool
RIP Pete Sims
Posted 2nd Aug 2010 at 05:24
infosellerfsmail
Yea i have put a brand new battery on the car and in the key. The alarm works ok its just the immobilisor i think as the car just turns over and the pump isn't giving fuel???
Posted 2nd Aug 2010 at 13:40
webster
What about that fuel cut off switch? U tried pressing that?
Probably won't help at all but worth a try..
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 2nd Aug 2010 at 14:37
jeffers Forum Admin
Sticky fuel pump relay?? Mine was like that after being sat for a while.......
Team Running Engine again!
Team Negative Camber!
Posted 2nd Aug 2010 at 14:56
infosellerfsmail
Yea tried the fuel cut off switch dude.
Sticky Fuel Pump relay??
How do i unstick that or is it a new one?Oh and where is it?
Posted 2nd Aug 2010 at 18:57
It's on the back of the battery box mate....held on with an 8mm nut. Yes
Stan.
Posted 9th Aug 2010 at 04:04
russbez
in a similar situation myself, you have to wack the fuel cut off aka interia switch pretty good in order to get it to pop up and disconnect
interested to see how you get on Yes
My Rallye project thread
Posted 10th Aug 2010 at 13:43
infosellerfsmail
Ok so i have tested the fuel pump relay and it is clicking when the ignition is switched on but still no fuel pump prime or spark?. I am now thinking maybe unlocked ECU to see if that will start it? Or just unlock the one i have??? What you think??
Russbez been following your threads and looked at a few others like this and it seems to be a common problem not being able to diagnose it. As per my other thread on here even Peugeot don't know what's wrong with it. The thing is i don't wanna replace all the sensors to then find it still won't work!!!
Posted 12th Aug 2010 at 16:39
russbez
not sure about ecu mate, I tested mine on another rallye a few days ago, infact tested relay, inertia switch, fuel pump and ecu ; and it primed in his car.
from what i worked out from my f*cking horrid time in past week ; my problem seems to have been damaged loom, I move my fuel relay from one side of battery to the other = it starts working… put it back to where it should be sitting and the c*nt stops working.
earths:
earth wire coming out from engine loom (roughly located under thermostat housing which goes into a 13mm on the gearbox, the one closer to the bulkhead)
cable from negative battery terminal to gearbox earth, 50mm ish! away from above the earth
then same cable goes along to one of the two earthing points on chassis next to gearbox mount plate/housing thing.
earth cable from chassis loom, comes up from horn direction of the car, into engine the bay up to the earth point gearbox mount plate/housing.
earth coming from brake servo wiring, i put it into the earthing point closer to the battery mount
earth coming from engine loom, going onto starter motor (8mm)
and another earth going on to alternator (8mm)
drivers side near headlight
lives:
cable from battery goes to starter then to alternator
the alternator also has a cable attaching from the engine loom, this seems to power the double fuel relay (and possibly more)
pretty sure that comes from battery terminal has 2 lives going into the fuse box this seems to power lights + more etc
don’t take this as 100% correct, more like 99%
am off to go cry over my loom Yes
Posted 12th Aug 2010 at 18:07
spiky
crank senors on gearbox?
thought, not priming i'd say ineria or fuel pump relay, or missing earth somewhere
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 12th Aug 2010 at 18:12
spiky
or missing constant live on starter/alt
MY YouTube Videos'
russbez
damaged wiring loom??? Whistle
Cry
Posted 13th Aug 2010 at 14:00
infosellerfsmail
That's what i'm thinking russbez!! problem is im starting to loose all interest and have no patientce with the car anymore! I suppose to change the engine loom over isn't a huge job!!
I think i may try this!
Posted 13th Aug 2010 at 14:14
russbez
good luck
wonder who will get theres running first LOL
Posted 13th Aug 2010 at 21:48
infosellerfsmail
any luck with yours yet Russ?
I was just about to start the transfer and put a f*ck my life status on facebook and a mate is coming round with his dad who has worked on Peugeot's for 50 years "apparently"! He claims he can definetly at least diagnose the issue.
If he does i'll let you know.
If he doesn't wish me more luck as i've just realised howmuch of a pig this is when the engine is in.
Did you do a new engine loom change dude?
Posted 18th Aug 2010 at 21:59
did you try another relay or just assume it was working ok because it clicked?
Posted 19th Aug 2010 at 13:27
russbez
am afraid iv been sorted for a few days
Clicky
emm i have a mate who had a spare second hand loom, which i now owe him one back LOL
how did u get on with your mates dad?
Posted 19th Aug 2010 at 14:09
infosellerfsmail
You jammy git!! Lol i knew you'd beat me though!
In true "talk the talk" fashion nobody turned up so i have wasted time relying on someone else when i could have been out there doing it.
Good project thread though Russ she looks good dude. Out of interest i need to know 2 things:
1) When your ignition is on and you go to start the engine does the small red alarm light just below the fan blower on the left stay on when turning over or does it go out when you turn over?
2) How long did you sparky spend on the 6 and how much did it cost? also was he an Auto - electrician that was Peugeot specialist or just general?
I'm just looking at this loom i have and it looks like its been crushed a little.
Need a decent loom i can trust that works but cheap as i've thrown so much money at the 6 now its silly!
Well done though mate glad to hear its finally running after all that hard work.
Posted 19th Aug 2010 at 21:42
infosellerfsmail
I havent tried another relay dude only because its more money that i have to give to a peugeot dealer, however i did do the relay test with a multi meter as per the FAQ on here and it seems fine.
I'll change the loom and then if that doesn't work i'll try that next! If i have any money left!
Posted 19th Aug 2010 at 21:51
infosellerfsmail
Well i changed the loom and now have a running car! God knows why as they both look exactly the same but now it primes sparks and runs.
Really annoying as this has taken ages to fix!
Just goes to show that even though the loom looked ok doesn't always mean that it is!!
Posted 30th Aug 2010 at 00:51
did you use the old relay on the back of the battery or a different one? all i wanted to hear is if the relay was known working or not LOL ie compare against another
Posted 30th Aug 2010 at 01:59
