displaying posts 1 to 25 of 33
Author Subject: Rotrex filling procedure
simonjames
Can any of the charger lads shed some light on how i fill the charger, i remember Ash saying something about presurising it but as he has a shit memory he couldnt remember fully
MY EBAY ITEMS
07943066306
Posted 28th Jul 2010 at 15:38
birk
I blew down one of the pipes untill i could see the oil coming out the other end of the charger oil line, take some doing though Thumbs up
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 28th Jul 2010 at 15:45
rallyestyle
LOL Thats the way i did it too Yes
I think the manual for the charger should be on Rotrex's site Simon, have a look at that as it describes how to do it, you just need to replace the 15psi pressure line with your mouth Laugh
Just Drive It
Posted 28th Jul 2010 at 15:47
cosmic spanner
Moral objector
Yeah it's a bit of a shit procedure TBH... you should download the instructions off the Rotrex site.
Their idea is once it's all hooked up, you fill the tank, loosen the banjo bolt to the charger IN hole.
Then using your air compressor (you do have one of those, right? Laugh) and a "rag" wrapped round it you hold the air hose up to the unscrewed dipstick hole (very classy for such an important procedure on such expensive piece of kit) and this will form a seal so you can pressurise the fluid and force it up towards the IN hole on the charger. When you see steady blue traction fluid coming out the banjo, nip it tight.
That's the theory. But without an air compressor (and it being sunday, nowhere to hire one) I tried blowing, sucking, using a diesel priming pump, gravity, voodoo.. all sorts.. couldn't get it reliably primed. Angry You guys who reckon you did it with your mouth... scare me! Blink Where did you learn how to blow like that?! Whistle
In the end, I modified an eazi-bleed and an R888 to give me an "air hose", did the trick.
WARNING: I don't know if you realise - I didn't at the time I was spraying the shit round like champagne on the winners podium Doh - but the Rotrex traction fluid is Very Expensive. Think "Unicorn Sperm" levels of expensive. So try to be careful and get the priming done right with not too much waste!
BTW, once it's running, you can tell if it's priming properly by whether the cooler is getting warm (it's on the return) and if you slightly loosen the OUT banjo on the rotrex you should see fluid flowing out.
HTH Thumbs up
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 28th Jul 2010 at 16:06
judders
Clicky
PDF from Rotrex site fella
Hope the clicky works lol
Posted 28th Jul 2010 at 16:08
rallyestyle
judders wrote:
Clicky
10/10 for the newb Thumbs up
Just Drive It
Posted 28th Jul 2010 at 16:10
judders
rallyestyle wrote:
judders wrote:
Clicky
I do try lol What do i win ? Roll eyes
Posted 28th Jul 2010 at 16:12
rallyestyle
judders wrote:
rallyestyle wrote:
judders wrote:
Clicky
Erm... a week of not being flamed LOL Razz
Just Drive It
Posted 28th Jul 2010 at 16:18
blaze wip
judders wrote:
rallyestyle wrote:
judders wrote:
Clicky
A world renowned ratboy reacharound. Wink
mechanical_repairs wrote:
i feel like giving her a good dry bumming session.
Posted 28th Jul 2010 at 16:36
fletch
Track Head
rallyestyle wrote:
judders wrote:
Clicky
Yes
Most helpful newb ever? Dunno
Posted 28th Jul 2010 at 18:18
andy306gti
What I did was basically what rotrex suggest only I user an old bike innter tube cut in half with one end tied. The other end i jubileed to a socket and made a gasket out of a latex glove.
I then connected my tyre inflator and used that by pushing the socket over the dipstick hole.
Worked a treat.
Posted 28th Jul 2010 at 18:25
russbez
Clapping
agree totally, pretty sure i still have spare from last time... its alllll mine LOL
expensive stuff Yes
My Rallye project thread
Posted 28th Jul 2010 at 18:27
simonjames
Cheers all, i'll get around to making brackets for everything this weekend hopefully and get on with filling up
MY EBAY ITEMS
07943066306
Posted 28th Jul 2010 at 19:10
rallyestyle
Clapping
expensive stuff Yes
I got a whole bottle sitting in my shed, best part of 90 quid Crazy It's like some sort of cure all elixier Laugh
Just Drive It
Posted 29th Jul 2010 at 20:15
I know it's an old thread but I used one of the small mobile tyre compressors that have the torch built in that plugs into the fag lighter, I just wrapped some self amalgamating tape around the end of the hose until it was slightly bigger than the charger reservoirs dipstick hole, so it would seal, you could use electrical tape aswell.
have your spanner or socket on the banjo bolt ready to tighten it back up when it pumps out and have some rag infront of the charger to stop it flowing down and dripping onto the p/s pump.
It is a s**tty method for an expensive bit of kit, aswell as feeling the oil cooler for heat you should see some movement/flow of the oil in the reservoir.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 24th Mar 2012 at 00:22
tvrfan007
What a fecking faff that looks like. Got to do that when i get home as the charger fluid needs a change.
Not wrong about it being unicorn sperm prices either.
Why can't you just raise the reservoir above the charger and fill it that way? or backfill the line?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 26th Mar 2012 at 16:21
I used a foot pump attached to the outlet end of the pipework and slowly pumped away! Blush
Posted 28th Mar 2012 at 14:34
That's probably the best idea ratman.
It's a s**t procedure, and from what I've read the system will find its own oil level and spit any extra out it doesn't want out of the breather cap.
Posted 28th Mar 2012 at 17:50
marco gti6
rallyestyle wrote:
judders wrote:
rallyestyle wrote:
judders wrote:
Clicky
Laugh my ass off
Posted 28th Mar 2012 at 17:54
Thread revival I know but has anyone tried just raising the tank above the charger till it p**ses out the banjo bolt? Gotta prime mine up for the first time tonight :/ if not I'll resort to the electric tyre pump and rig something to make a seal...
Posted 28th Jun 2012 at 14:18
smegal
I can't really help, but let me know how you get on. Sound s like you're progressing well with it.
Ex SC-6
Now in a Megane R26
Posted 28th Jun 2012 at 14:44
Yes mate nearly ready to run Big grin all painted up as well got the inlet manifold back from the powder coaters this morning looks awesome but as the letters are still there I want them black so they stand out. Been painting them in with a cocktail stick fiddly as f**k! Lol just gotta fit the manifold prime the charger and setup the drive belt and she's a runner hopefully Big grin I'll send you some pics or have a look on fb at some I put on yesterday "Pete Armz Dann"
Have got the full rotrex instructions online but think there has to be an easier way that what they say to do it. As long as there's a steady stream of fluid there at the oil inlet it should be fine. May get round to it onight may wait till the weekend.
Posted 28th Jun 2012 at 14:57
It's easy enough, it sounds more a ball ache than it is.
It doesn't take long either.
Posted 28th Jun 2012 at 15:24
Think I'll have to use a suitable sized grommet and a length of tube offa tyre Pump. Unless one of my mates can blow hard enough........ LOL
Posted 28th Jun 2012 at 15:29
Wrap electrical tape or self amalgamating tape or even parcel tape around the bit the air comes
Out of until it's a nice sealed fit when you press on it, ten with the spammer on the banjo bolt ready to tighten it up when it spews out!
Posted 28th Jun 2012 at 16:32
