Author Subject: ITB/Coilpack
Right, I am trying to get everything sorted so I can finally get my throttle bodies fitted. I think I have everything I need except a solution for the coilpacks.
I have a DTA ECU and loom (older style, but manages fuel and ignition), but it doesn't seem to have wiring for single coil packs.
Can anyone recommend a dizzy/coilpack configuration that I could use? and ideally, where I can source it from.
Thanks Cheers
Posted 14th Jul 2010 at 13:56
spiky
306 1.8 8v Smile
as seen on my build thread Smile
surely it can run a single coil pack?
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 14th Jul 2010 at 14:37
Cheers Steve Thumbs up
Sorry, that was worded badly. I'm sure it can run a single coil pack, but I meant it can't run single coil packs x4 (if that makes sense) LOL
I don't have much knowledge on the loom, but that's my fault for rushing in and buying second hand Blush
I will take a look at your project thread.
Posted 14th Jul 2010 at 14:42
Will this work?
Posted 14th Jul 2010 at 15:28
I'd contact DTA and ask them. I know some coilpacks don't work the same as others and you don't want to damage the ECU.
Posted 14th Jul 2010 at 15:52
nearly any 8 valve pug will do the trick, inc TU engines, just like the one linked to Smile
Posted 14th Jul 2010 at 16:29
spiky
thats what i actually bought for my car, hasnt given me a single issue
i use CORSA B leads too, just incase you looking for a set that will fit Smile
MY YouTube Videos'
Posted 14th Jul 2010 at 18:12
Thanks people Big grin
Steve, did you get standard Corsa B leads? or uprated ones?
Posted 14th Jul 2010 at 18:32
spiky
S/H standard one's off ebay Big grin £7
MY YouTube Videos'
Posted 14th Jul 2010 at 18:35
itchytrigafinga
Using a stadard 8v coil pack off the TU engine in mine, no problems. I also have a DTA ECU with ITB's. I bought some new leads from here:
http://www.performanceleads.co.uk/
Not too pricey and are painted blue so look good under the engine cover, too. Oddly on their website they have leads listed specifically for a GTi-6/Rallye model, even though the standard car doesn't use them.
Just on that website now, which ones did you buy? (what model corsa)
I may buy some off ebay as Steve has suggested. Getting this done has been more costly that I thought, so cheaper the better LOL
Posted 14th Jul 2010 at 18:39
All the niggly items sure do add up don't they? Wink
Posted 14th Jul 2010 at 18:58
rallyeash
ive got a 106 8v coilpack on corsa ht leads
309 3dr K20 Type R
Posted 14th Jul 2010 at 22:43
miles
Use a std 16v one, You just have to trim a few bits off to get it to fit but looks a hole load neater and no plug leads either, It works just as the normal coil pack
www.pugracing.com
Posted 15th Jul 2010 at 01:06
blandy
ive just recieved my xsi coil pack off ebay and it looks massive with a cover on top? Does this sound right i guess i can trim it up to fit just wondering if ive got the right part or not
Posted 10th Dec 2015 at 11:26
fatlapit
Yes its right u will have to remove some of the lugs on the head and it will bolt straight in
Posted 10th Dec 2015 at 11:47
sounds like you got the later type from the plastic cam cover type.
Posted 10th Dec 2015 at 11:54
blandy
cool ill chop it to fit then
thanks
Posted 10th Dec 2015 at 12:20
demondriverdan
I got one of those from Miles but decided against fitting it as I didn't want to chop anything from the head and it would have been a pain to take off with the strut brace on. Ended up going with the Corsa coilpack and HT leads
Rallye Race Car
Posted 10th Dec 2015 at 12:47
This is what I've done .
I used a Powerfile from Black & Decker to adjust & make fit ...looks amazing but I wouldn't want to file by hand Thumbs down .
I just made the Oil cap cutout bigger & apart from that you can't tell the difference when fitted from standard Thumbs up
Posted 10th Dec 2015 at 17:29
demondriverdan
The reason I didn't want to do it on mine is that it's a Longmans ported and polished head. Cutting off all of a few of the tabs to hold individual coilpacks on reduces the resale value / opportunity slightly as you couldn't use it with standard coilpacks.
Rallye Race Car
Posted 10th Dec 2015 at 19:33
blandy
So did you leave the original cover on the pack and mod that to fit?
I know on my 306 that miles fitted the bodies to a few years ago that had a xsi coil but it sat under the original cover so must of had the original cover etc removed.
My manifold is due tomorrow so prob start fitting over the weekend
Posted 10th Dec 2015 at 20:30
I'm using the standard single coil packs on mine using a DTA S60 Pro ECU.
Can you not use the standard engine loom and add/remove parts you need or don't need for the ITB conversion?
Posted 11th Dec 2015 at 11:32
