Author Subject: Handbrake light on dash flickering?
misschief
Was driving home from the Safari park today and the handbrake light started flickering whenever I went over a bump and any uneven ground. handbrake wasn't on and i didn;t notice anything changing by pushing the handbrake down or pulling it up a little. Can I safely assume it's just the switch and just ignore it?
Posted 4th Jul 2010 at 03:31
tvrfan007
Low brake fluid level in the master cylinder.
The handbrake light doubles up as a warning.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 4th Jul 2010 at 04:08
misschief
Hmm that is a little worrying, I had the brake pipes replaced about 6 months ago and the system was bled and new fluid used at the same time.
Posted 4th Jul 2010 at 04:44
tvrfan007
not necessarily a sign of a leak. If you're coming up to pad and disc replacement all round it can be enough to trigger it as you've displaced quite a volume of fluid - assuming it was max at the time. Have a nosey.
I'm Si btw Tee hee
Posted 4th Jul 2010 at 12:57
chris with a pug
Doesnt that light do the pad wear sensors too?
Posted 4th Jul 2010 at 15:49
jeffers Forum Admin
Yes the pad wear sensors turn that light on, check your front pad matey!Wink
Team Running Engine again!
Team Negative Camber!
Posted 4th Jul 2010 at 16:47
misschief
So where will I find the brake fluid reservoir? Discs got changed a couple of years ago according to the receipt I found so perhaps it's just pads.
Posted 4th Jul 2010 at 19:06
tvrfan007
It's the master cylinder. Open the bonnet, back left right behind your oil filler cap.
Pad sensor as above is a good suggestion. I don't have those on mine, but surely they would bring on a permanent light as it'll have eaten through the sensor?
I'm Si btw Tee hee
Posted 5th Jul 2010 at 00:08
Not pads, well not on phase 3's anyway as that brings on a different light.
Posted 5th Jul 2010 at 00:15
misschief
I have a Phase 2.5. will check the master cylinder next time I have the bonnet open.
Posted 5th Jul 2010 at 01:29
rich-6
Nor on phase 2s as they have a seperate light, as above it's the master cylinder level
Cool
RIP Pete Sims
Posted 5th Jul 2010 at 21:57
misschief
Righto cheers guys. This is why I love this place sometimes, fantastic advice and quickly too! Will get some Dot 4 (as it says on the cover) asap. I don't see a 'Min/Max' marker on it though, is it dangerous if I overfill?
Posted 6th Jul 2010 at 04:16
stu
IIRC the marker is on the left hand side of the reservoir as you look at it when standing in front of the car.
Posted 6th Jul 2010 at 05:36
tvrfan007
As above, they're marked on the left hand side of the master cylinder. Max is written with a little arrow pointing just below the 'flat' roof of the actual reservoir, if you ignore the part with the neck/cap.
I'm Si btw Tee hee
Posted 6th Jul 2010 at 17:27
misschief
Ok, so how much should I be buying of this stuff? Will 250ml be enough? Should I buy 500 or 1L? is it likely I have a leak somewhere or just the brake fluid being 'used'?
Posted 8th Jul 2010 at 05:05
misschief
Spot on as always guys. Filled it up (and a little bit more, will it cause a problem?) and no light all the way home.
Posted 9th Jul 2010 at 05:04
tvrfan007
Not really a problem if you have a little too much fluid in. It is probable there wasn't a top up after new brakes were fitted (ie master cylinder never returned to max level) or your pads and discs are all heading for replacement. Smile
I'm Si btw Tee hee
Posted 9th Jul 2010 at 17:25
