Author Subject: Starter motor not engaging
bezza90
This is actually a problem with the wifes 1.4 Y plate Megane. When she tries to start it (especially after she has just driven it and needs to restart it), the starter motor turns fast, but does not turn the engine over. It will eventually start but takes many tries.
I have not had a look at it properly yet but could do with some pointers about what it might be. Does it sound like a tooth is missing from the starter motor? When I get back I will try it and see if moving the car slightly when in gear allows it to then turn the engine over.
Does anyone have any ideas/solutions?
'00 Astor Grey GTi-6
Team: 'EVO Triangle'
This is a quantum car. I don't know where I am, but I'm going really fast.
PS3 ID: Skaankypuppy
Normally play GT6
Posted 30th Jun 2010 at 15:34
will130787
Sounds like the stater motor is not throwing out properly to catch the flywheel. Probably a new starter motor bud, my Mums 4x4 does exactly the same thing and a starter sorted it. Wink
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 30th Jun 2010 at 17:43
Sounds like a sticky started Thumbs up
Posted 30th Jun 2010 at 18:11
oldbrownshoe
heat it with crowbar while runing.
French military victories?
Did you mean French military defeats?
Posted 30th Jun 2010 at 20:43
ablister
could be flywheel ring gear with missing teeth: starter will turn but not be in contact with engine. Need to remove gearbox to replace but can sometimes check condition of ring gear by removing starter and looking through hole
306 rallye, Richard Longman engine
rc10gt
Posted 30th Jun 2010 at 23:43
bezza90
Cheers everyone.
I will first take a look at the starter on the weekend when I have a bit more time. Sods law - it never does it when I am about. I took it out for a spin, stopped several times and re-started it - nothing.
A little additional information would be that it will eventually start, would that rule out missing teeth on the flywheel etc and point more towards the solenoid which engages the starter? Unsure
She does not move the car when it happens so all the transmission would remain in the same location.
I hope it is not the flywheel as that is not a job I fancy doing!
I also need to change the VSS, gearbox oil and engine oil on mine this weekend before going to the F1 next week. I will be busy!
Normally play GT6
Posted 1st Jul 2010 at 00:11
ablister
probably will be starter soleniod then, easier job than a flywheel (and cheaper too)!
rc10gt
Posted 1st Jul 2010 at 00:19
