Author Subject: Cam cover leak-Sorted
sixygti2
Ok so below you can see the pic. But you might also be able to make out just underneath the oil filler cap all the horrible crappy oily staining and a tiny little pool of oil right under the cap on the joint. I wiped it away and it came back. So obviously there is a leak, but I'm not sure what exactly need to be done.
The engine doesnt sound the best, so am also thinking it needs something major sorting out, pistons/guides maybe...
Could anyone give me any good news regarding this? Sad
sixygti2 has attached the following image:
Still watching you...
Posted 24th Apr 2011 at 06:19
sixygti2
Another shot which shows discolouration lower down also
Posted 22nd Jun 2010 at 00:15
sixygti2
Ok so according to some other threads, it looks like it is just the cam covers that need resealing. Unsure
Is this a DIY jobby or a garage jobby?
Posted 22nd Jun 2010 at 00:30
smighall
Smeg-all
Yup just looks like a small leak from a cam cover. Whip them off clean them all up / remove the old gasket, then put some instant gasket all around cam covers back on to 80% torque, leave for a couple of hours then torque them up fully.
Meh
Posted 22nd Jun 2010 at 00:50
sixygti2
Thanks mate, was hoping it was just that. Just need a torque wrench now and to find what torque they go for!
Is there anything else worth checking out whilst the covers are off?
Posted 22nd Jun 2010 at 00:55
brochloon
that theres still oil inside lol.
PH3 Cherry 6
Posted 22nd Jun 2010 at 01:20
sixygti2
Thanks.
So the torques HERE show 10Nm for the cam covers. Just to confirm this is correct for our cars?
So, tweak then to 8Nm, leave for a few hours and then put them up to 10Nm!?
Danke
Posted 22nd Jun 2010 at 01:49
lwgti-6
sixygti2 wrote:
Thanks.
Danke
Correct!
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 23rd Jun 2010 at 02:30
sixygti2
Forgot to ask, what would you use to clean them up properly?
Merci
Posted 26th Jun 2010 at 02:07
sixygti2
Ok, so I still need to get this sorted, just keep forgetting to do it, so will hopefully be getting down to it soon!
When refitting the covers, is it good practice to use a new set of bolts, or will the old ones suffice?
Also, I have heard of tightening them up in a spiralling pattern, is that correct or am I getting confused with something else? And how exactly do you do that? Unsure
Anything else to consider whilst I'm there?
Ta
Steve
Posted 1st Feb 2011 at 23:24
Unsure
Remove the old gasket?
No chance I would do that,have u seen how much sealer you need to use if you remove the gasket that is bonded to the covers?
Once the orig gasket is removed there is a massive gap between cover and cam carrier,right bodge using sealet in a gap that big IMO.
Just clean up old gasket with petrol on a rag then use a thin smear of sealer when refitting.
Posted 2nd Feb 2011 at 17:13
matt evans
Kev, would something like Blue Hylomar do the job?
honestly3k wrote:
owain wrote:
Posted 2nd Feb 2011 at 18:49
Not keen on Hylomar myself.
I always use gasket maker type stuffWink
Got some at the minute that is silver/aluminium colour,so can't really see it compared to the orange/blue that some people use!LOL
Pro seal Aluminium sealer
Posted 3rd Feb 2011 at 01:50
ant_kernow
just buy some covers with the seals intact....SIMPLE!
team umpalumpa.
Posted 3rd Feb 2011 at 01:48
sixygti2
I have now done this very thing! Yes
Just need to source a wrench that has a low enough torque range! Have been tempted to just make do without one and just "feel" when its right, but think I should do it properly LOL
Steve
Posted 17th Feb 2011 at 21:16
oldbrownshoe
you'll need to be careful with those RTV stuff,
too much and it can yanked inside, i prefer the original gasket and happy with Permatex gasket remover spray .
French military victories?
Did you mean French military defeats?
Posted 17th Feb 2011 at 22:34
sixygti2
Have managed to change these over today and I noticed that one of the new covers has an extra hole to screw something into which the original ones didn't Erm?
Not sure what its for as it doesn't go right through the cover
Anyone know why its there?
Posted 24th Apr 2011 at 06:22
There are two types because they originally planned to run the fuel pipes over the cam covers.
Posted 24th Apr 2011 at 13:07
sixygti2
Thanks rudolf Thumbs up
Posted 24th Apr 2011 at 16:46
