Author Subject: Bleeding tubes
brendanm
Does anyone know what size tubing is needed to fit on the nipples to drain the fluid from them and where can you can buy them?
All of the tubes from my Eazibleed kit have disappeared since the last time I used it and I don't want to buy a complete new kit if I can avoid it.
Posted 21st Jun 2010 at 02:53
cwspellowe
I just went to an aquatics shop, found some tubing and went "aye, that'll do"
f*ck paying £20 for an easy bleed kit Erm?
Bye bye Sundance Kid Sad
Posted 21st Jun 2010 at 03:58
I bought a reel of washer jet hose from Halfords, cost about £4 for 5 feet and seems to do the job nicely.
Posted 23rd Jun 2010 at 17:51
I usually just use the cheap tubes from a local motor factor, about £3-4 or so, they have a one way valve on the end, or a more expensive version at about £6 or so comes with a square pot.
Posted 23rd Jun 2010 at 17:52
pugmarshall
I don't use any. Shock
Posted 23rd Jun 2010 at 21:50
lotek
so how you gonna know if the air bubbles are out? ???
Laugh my ass off
Posted 23rd Jun 2010 at 23:58
pugmarshall
I DONT! LOL Huh? Sad
Posted 24th Jun 2010 at 00:45
NHS silicon air mask tube Whistle
Posted 24th Jun 2010 at 02:15
I can just picture you creeping through the wards in the dark with your stanley knife, nicking some poor buggers air hose! LOL
Posted 25th Jun 2010 at 14:42
brendanm
The washer jet hose that they had in stock was of too small a diameter.
In the end I got some fuel line pipe from an independant car spares shop as it was closer than any aquatic centres that I could find. I will just have to watch for the bubbles in the fluid.
Posted 25th Jun 2010 at 18:08
I used go-kart fuel hose, nice and soft and flexible.
Posted 25th Jun 2010 at 18:11
LOL
Posted 25th Jun 2010 at 20:15
gilesy
daveyboy wrote:
I can just picture you creeping through the wards in the dark with your stanley knife, intefering with pensioners
LOL
Posted 25th Jun 2010 at 23:12
allesclar
SIMPLE.
get a jam jar, empty of course Wink
fill it half way with brake fluid.
get a pipe like one from a fish tank and tighten it up against the caliper nipple. put the other end in the jar making sure its at the bottom with brake fluid above it.
undo the bolt and get a friend to pump the brake. while you keep an eye on the resouvoir, making sure it does not go too low. look at jar as they push the pedal, if no air bubbles come out, job sorted.
the brake fluid already in the jar stops the brakes from sucking air back in, it will suck the brake fluid up between pumps on the brake Smile
f*ck paying for something so simple Smile
Thumbs up
Team allesclar ®
Posted 25th Jun 2010 at 23:16
