displaying posts 26 to 31 of 31
Pages (2): 1 [2]
Author Subject: 2.1
pugheaven
ok point taken, thanks for the help.
Posted 24th Jun 2010 at 16:42
binkagti
Ollie, why do you want to get to 2.1?
You know my engine is 2044cc and that seems to work, just curious mate
TEAM Supercharged Rallye
Posted 24th Jun 2010 at 17:15
pugheaven
what crank are you usin? Colin suggested it to me as that is what he was/is planning on doin. More torque i guess?
Posted 24th Jun 2010 at 18:10
binkagti
Standard crank i think, but i am running prob around 350 ft / lbs? do you need more? Good luck dude,
Posted 24th Jun 2010 at 23:03
pugheaven
not usin the same turbo as you so i wont get the same power! Only wantin 300hp, bein different as well.
Posted 25th Jun 2010 at 11:13
oldbrownshoe
jarrus464 wrote:
Could be good, but lighter isn't always better though mate Smile
I think there might be a good reason why PSA went back to cast iron over alloy
the reason is the shit alloy PSA used to build the block with, very sensitive to coolants so they need to develop special liquid.
bobdylan_55 wrote:
bigger stroke but shorter con-rod will give lower compression.
reason pug went back to cast is because its probably stronger and puts the weight over the driving wheels which is better for traction.
anybody watched the latest topgear stunt on a 207gti? they timed it, then stripped it out and timed it again and was faster standard...
no , it isn't
the weight should be concentrated before the wheels , not on or after the axles.
what happpened in topgear is that by stripping the car they destroyed it's weight distribution.
heavier car with better weight distribution handle better then lighter car with bad weight distribution, as long as the weight differences is not marginal.
French military victories?
Did you mean French military defeats?
Posted 25th Jun 2010 at 14:17
Pages (2): 1 [2]
