displaying posts 1 to 25 of 31
| Author | Subject: 2.1 |
309btcc
**DODGY SELLER** Location: england Registered: 07 Jul 2009 Posts: 530 Status: Offline |
what diesel crank do i need to do a 2.1 6 engine? |
1.9or a 1.9 petrol. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
309btcc
what do i need too do too make it all fit with out any issues??? |
matty_rallye
Senior User Location: Devizes Registered: 28 Oct 2005 Posts: 966 Status: Offline |
87mm bore, pistons to suit. Custom rods / pistons to lose some height of the stroke due to the 2mm increase of crank stroke.________________________________________ 2.1 16v 306 Rallye. |
matty_rallye wrote: 87mm bore, pistons to suit. Custom rods / pistons to lose some height of the stroke due to the 2mm increase of crank stroke. Looks like you won't be buying my pistons after all Chris ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
309btcc
not shure yet guna do sum more research |
rallyeash
the s16 pistons and rods can be fitted i believe but your still limited on cam choice on standard pistons________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
karoshi
Junior User Location: Sydney Registered: 07 Mar 2010 Posts: 60 Status: Offline |
There is an increase in compression with an increase in stroke isn't there?About how much? ________________________________________ CheersBill |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
karoshi wrote: There is an increase in compression with an increase in stroke isn't there? About how much? It would depend how you build the engine and where the pistons sit in relation to the deck of the block. ________________________________________ Ryan |
309btcc
cont knw what too do know as 2litre is a good engine anyway..... |
rallyeash
what are you planning on using the car for? track work?________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
309btcc
more track and weekend car for fun. was toying with a mi16 build due to it being 20kg lighter |
jarrus464
Junior User Location: Great Wyrley, Walsall Registered: 14 May 2007 Posts: 92 Status: Offline |
Could be good, but lighter isn't always better though mate ![]() I think there might be a good reason why PSA went back to cast iron over alloy |
bobdylan_55
Seasoned Pro Location: derby Registered: 28 Mar 2009 Posts: 1,466 Status: Offline |
bigger stroke but shorter con-rod will give lower compression.reason pug went back to cast is because its probably stronger and puts the weight over the driving wheels which is better for traction. anybody watched the latest topgear stunt on a 207gti? they timed it, then stripped it out and timed it again and was faster standard... ________________________________________ 309 GTi6-T |
jarrus464
no I haven't seen that, you have a link?It could be down to the suspension that, probably more roll due to it sitting higher up, |
309btcc
ok cool i just dont know what too do atm |
bobdylan_55 wrote: bigger stroke but shorter con-rod will give lower compression. only if you make the rod or piston too short, get it right, it WILL be higher. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
leito6
Newbie Location: Buenos Aires Registered: 24 Sep 2009 Posts: 20 Status: Offline |
I'm going down this road at the moment with my engine rebuild. 88mm crank from a XUD9 and 86,5mm forged pistons (1mm lower compression height). End result is circa 2070cc and 11,16 to 1 compression ratio. I'm making the valve pockets 1mm lower in order to have more room to play with timing and bringing the compression down to approximatelly the std ratio. |
I would leave the compression ratio as it is, though it is wise to enlarge the cutouts.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
bobdylan_55
welshpug! wrote: bobdylan_55 wrote: bigger stroke but shorter con-rod will give lower compression. only if you make the rod or piston too short, get it right, it WILL be higher. i was refering to kiroshi's earlier comment saying that increasing stroke will increase compression. I was trying to say if its too high you could reduce the size of the rods to get it into a reasonable figure without machining the pistons. ________________________________________ 309 GTi6-T |
karoshi
My question upon reflection was one of a numpty. The discussion resulting however is very interesting! ________________________________________ CheersBill |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Im thinking of building a 2.1 turbo gti6. Iv already got the pistons and rods, 86mm and cr 8.1. If i was to use a 1.9 crank and take 1mm off the crown of the piston what cc will this give and what will the cr be? Thanks Ollie |
2044cc, not sure on the compression, do the pistons have the 4 valve cutouts?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugheaven
the pistons are wossner items, they do have cut out on the crown only and not in the dished part. Would it be safe to take 2mm off them. A friend of mine spoke to brett x longmans builder and he suggested it! Bit worried about takin meat off the pistons. |
depends how deep the valve cutouts are, you'd need to make them deeper too ideally, you will only need to take 1mm off as the stroke is only increased upwards by 1mm.trouble is that they are dished, so it'd be quite an involved process to take the material off accurately. I'd leave it at 86mm tbh, its a lot of messing around for not much benefit as its a Boosted application, if it was N/A and you had flat top pistons it'd be a different matter, or if you were ordering new pistons. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
