displaying posts 1 to 25 of 31
Author Subject: 2.1
309btcc
**DODGY SELLER**
what diesel crank do i need to do a 2.1 6 engine?
Posted 8th Jun 2010 at 00:53
or a 1.9 petrol.
Posted 8th Jun 2010 at 01:01
309btcc
**DODGY SELLER**
what do i need too do too make it all fit with out any issues???
Posted 8th Jun 2010 at 01:05
matty_rallye
87mm bore, pistons to suit. Custom rods / pistons to lose some height of the stroke due to the 2mm increase of crank stroke.
2.1 16v 306 Rallye.
Posted 8th Jun 2010 at 02:48
Looks like you won't be buying my pistons after all Chris Wink Smile
Posted 8th Jun 2010 at 02:55
309btcc
**DODGY SELLER**
not shure yet guna do sum more research
Posted 8th Jun 2010 at 03:00
rallyeash
the s16 pistons and rods can be fitted i believe but your still limited on cam choice on standard pistons
309 3dr K20 Type R
Posted 8th Jun 2010 at 15:08
karoshi
There is an increase in compression with an increase in stroke isn't there?
About how much?
Bill
Posted 8th Jun 2010 at 17:46
ryangti6
About how much?
It would depend how you build the engine and where the pistons sit in relation to the deck of the block.
Ryan
Posted 8th Jun 2010 at 23:13
309btcc
**DODGY SELLER**
cont knw what too do know as 2litre is a good engine anyway.....
Posted 9th Jun 2010 at 00:33
rallyeash
what are you planning on using the car for? track work?
309 3dr K20 Type R
Posted 9th Jun 2010 at 00:38
309btcc
**DODGY SELLER**
more track and weekend car for fun. was toying with a mi16 build due to it being 20kg lighter
Posted 9th Jun 2010 at 00:43
jarrus464
Could be good, but lighter isn't always better though mate Smile
I think there might be a good reason why PSA went back to cast iron over alloy
Posted 9th Jun 2010 at 04:51
bobdylan_55
bigger stroke but shorter con-rod will give lower compression.
reason pug went back to cast is because its probably stronger and puts the weight over the driving wheels which is better for traction.
anybody watched the latest topgear stunt on a 207gti? they timed it, then stripped it out and timed it again and was faster standard...
309 GTi6-T
Posted 9th Jun 2010 at 10:16
jarrus464
no I haven't seen that, you have a link?
It could be down to the suspension that,
probably more roll due to it sitting higher up,
Posted 9th Jun 2010 at 20:08
309btcc
**DODGY SELLER**
ok cool i just dont know what too do atm
Posted 9th Jun 2010 at 20:45
only if you make the rod or piston too short, get it right, it WILL be higher.
Posted 10th Jun 2010 at 04:59
leito6
I'm going down this road at the moment with my engine rebuild. 88mm crank from a XUD9 and 86,5mm forged pistons (1mm lower compression height).
End result is circa 2070cc and 11,16 to 1 compression ratio. I'm making the valve pockets 1mm lower in order to have more room to play with timing and bringing the compression down to approximatelly the std ratio.
Posted 10th Jun 2010 at 09:13
I would leave the compression ratio as it is, though it is wise to enlarge the cutouts.
Posted 10th Jun 2010 at 16:00
bobdylan_55
i was refering to kiroshi's earlier comment saying that increasing stroke will increase compression. I was trying to say if its too high you could reduce the size of the rods to get it into a reasonable figure without machining the pistons.
309 GTi6-T
Posted 10th Jun 2010 at 16:26
karoshi
My question upon reflection was one of a numpty.
The discussion resulting however is very interesting!
Bill
Posted 10th Jun 2010 at 18:46
pugheaven
Im thinking of building a 2.1 turbo gti6. Iv already got the pistons and rods, 86mm and cr 8.1. If i was to use a 1.9 crank and take 1mm off the crown of the piston what cc will this give and what will the cr be? Thanks Ollie
Posted 24th Jun 2010 at 15:51
2044cc, not sure on the compression, do the pistons have the 4 valve cutouts?
Posted 24th Jun 2010 at 16:00
pugheaven
the pistons are wossner items, they do have cut out on the crown only and not in the dished part. Would it be safe to take 2mm off them. A friend of mine spoke to brett x longmans builder and he suggested it! Bit worried about takin meat off the pistons.
Posted 24th Jun 2010 at 16:08
depends how deep the valve cutouts are, you'd need to make them deeper too ideally, you will only need to take 1mm off as the stroke is only increased upwards by 1mm.
trouble is that they are dished, so it'd be quite an involved process to take the material off accurately.
I'd leave it at 86mm tbh, its a lot of messing around for not much benefit as its a Boosted application, if it was N/A and you had flat top pistons it'd be a different matter, or if you were ordering new pistons.
Posted 24th Jun 2010 at 16:38
