Author Subject: cams?
309btcc
**DODGY SELLER**
what are the bigst cams i can run on standard internals
Posted 3rd Jun 2010 at 02:00
Rich E Forum Admin
Kent PT81's if the head hasn't been skimmed, but you'll need to time them up carefully to make sure you don't exceed the maximum lift available at TDC.
Posted 4th Jun 2010 at 00:27
rallyeash
have a search and you will see there isnt much cam choice available with standard pistons and without taking the head off you arent sure if it hasnt had a skim. Get some decent pistons in there and do it right Thumbs up
309 3dr K20 Type R
Posted 4th Jun 2010 at 01:51
309btcc
**DODGY SELLER**
expensive tho ash and big job i just wana get pt81s and btcc inlet and remap pedro did that and got 215bhp that is enuf for me
Posted 4th Jun 2010 at 01:57
rallyeash
LOL you wont see 215 from those mods! unless you have rollers set up for pub talk
309 3dr K20 Type R
Posted 4th Jun 2010 at 02:01
309btcc
**DODGY SELLER**
really pedro rekons he did and the car is a rocket destroys type rs etc
Posted 4th Jun 2010 at 02:03
rallyeash
iirc btcc inlets are designed for high powered engines and no good on standard (ish) lumps
a set of cams and a remap from say chipwizards may see you in the mid 180's.
309 3dr K20 Type R
Posted 4th Jun 2010 at 02:07
309btcc
**DODGY SELLER**
ohh hmmm i dont get how his car can be that quick ten on just that ??
Posted 4th Jun 2010 at 02:10
LOL
as Daveyboy found IIRC, a BTCC inlet will lose some torque midrange, they were made to suit sustained high revs with long duration cams, not what you'd find from a mildly modified road engine.
you'd be much better off retaining a 100% standard inlet manifold, OR getting a proper set of throttle bodies.
best bet if you can't afford a decent set of pistons is to have the cutouts made deeper, Martin (CRF450) and sandy brown can get this done.
Posted 4th Jun 2010 at 02:12
309btcc
**DODGY SELLER**
do i have too take the pistons out for that
Posted 4th Jun 2010 at 02:13
rallyeash
yup
if you stick a set of cams in an unknown engine the pistons can eaasily be kissing the valves, you probably wont even notice for a while but you will soon find out! costing you more in the long run.
if you are looking at having your standard pistons machined best to pick up another set, have them done and swap them over. all can be done without removing the engine if needs be.
309 3dr K20 Type R
Posted 4th Jun 2010 at 02:23
309btcc
**DODGY SELLER**
thanx ash
Posted 4th Jun 2010 at 02:30
I have a good set of standard pistons out of a 60 thousand miler Chris, £50 and they are yours.
Posted 4th Jun 2010 at 05:06
jeffers Forum Admin
Dennis has machined pistons and PT81's in his track car and is managing about 195 horses, can't see the inlet making 20 horses, especially after seeing Jims inlet lose power.....Unsure
Team Running Engine again!
Team Negative Camber!
Posted 4th Jun 2010 at 05:33
