Author Subject: Shocks fubard?
darrengti
I bought a second hand set of koni adjustable dampers back along, not fitted them yet but was just giving them a tart up with some paint tonight as they've corroded a bit.
Main worry is the lack of resistance in the damper. The rears I really have to force to get the damper to compress, but the fronts just seems to push in easily, and there's no rebound. Have I been sold some dodgy shocks? I dont want to go to all the hassle of fitting them to find the car bounces all over the shop.
Posted 29th May 2010 at 01:12
cwspellowe
Tried adjusting them? They could be fully wound down...
Bye bye Sundance Kid Sad
Posted 29th May 2010 at 01:23
darrengti
just been out there now because I thought the same. easy as pie to push in, but stiff as hell to pull out. and I've just wound them to their stiffest setting.
Posted 29th May 2010 at 01:28
cwspellowe
I could be wrong but i'm pretty sure it's the pulling out that causes the damping. spring compresses along with the damper, spring rebounds and pulls damper out.
Any leaks?
Posted 29th May 2010 at 01:33
They will be on the stiffest setting - rebound will be about 5x as stiff as the compression, with them on softest it should be about 3x as stiff on rebound as compression
Posted 29th May 2010 at 01:37
cwspellowe
What I said. Sort of. Ninja
Posted 29th May 2010 at 01:45
darrengti
thanks guys. reassuring when the expert confirms it Smile got to pull my finger out an buy some top mounts now. get them fitted and get to the ring. that and one of phils ptfe gaskets is hanging around here somewhere...
Posted 29th May 2010 at 02:12
Don't try compressing and extending it...LOL
Posted 29th May 2010 at 02:16
