| Author | Subject: partner and berlingo wishbones |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
Had a look at a partner and berlingo today. It looks like the front subframe are the same as 306. the partner had cast wishbones while the berlingo has pressed steel ones like 306. Does anybody know if the berlingo or partner wishbones are longer, ie can be used on a 306 to give negative camber etc? also mthe cast ones could be a good upgrade for track cars as i would think they flex less |
Rich E
I've noticed before on Servicebox that the Xsara VTS shares some suspension parts with the Partner but nothing cross references to the 306.It would be interesting to see some side by side with 306 items ![]() ________________________________________ Rich |
dented_vts
Regular Location: london Registered: 23 Feb 2010 Posts: 440 Status: Offline |
I think they are the same- i believe the ones ECP sell for the Xsara come up as Partner on the sheet. Do the hubs look the same? I'll check my records when home.For neg camber- do AST not do adjustable top mounts? |
AST do make 2 way independently adjustable top mounts yes ![]() as for the rest of it, the bulkhead forwards under the exterior panels are near identical to a 306/xsara. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
dented_vts wrote: I think they are the same- i believe the ones ECP sell for the Xsara come up as Partner on the sheet. Do the hubs look the same? I'll check my records when home. For neg camber- do AST not do adjustable top mounts? Yes but they won't give you all that much. If they are longer wishbones will the standard shafts have enough spring in them to cope? Don't see why you couldn't make a balljoint longer somehow (cue phil with some rosejoints...) ________________________________________ Nothing to see here |
clen666
Just get him to knock up some of his tubular rosejointed wishbones, not sure what adjustment they have already but I'm sure he could extend them a bit.Though not as cheap as wishbones from a scrappy... ![]() ________________________________________ Team 'unintentional rat look' |
they wont be longer wishbones, they use the same length driveshafts.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
They've got enough adjustment that I run out of driveshaft travel before I run out of wishbone adjustment ![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
chop chop, weldy weldy ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Thinking about it...________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
get some 406 BE shafts, then you just need to shorten them instead of add metal ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
And fit the MA joints...And they're extra weight! ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
hmm, ahhh you have the smaller non ABS MA joints, not the larger ABS type that's the same as a BE joint, glad you only have 99 wabbits then ![]() thread hijack? ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Just a bit!Yeah, I'm on the special lightweight racing joints ![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
