displaying posts 1 to 25 of 33
Author Subject: Gearbox Removal
kezman7
I have had a look in the FAQ but cant find anythign about removing the 'box, I have undone (i think all the bolts but it dont seem to budge, What is the easyist way to remove it? Just alot of jiggling and force or am i missing something?
Posted 25th May 2010 at 04:11
Rich E Forum Admin
It's covered in the clutch change FAQ, but basically you just unbolt the box from the engine and it comes away.
If it won't budge then you've probably got bolts still in it somewhere.
Posted 25th May 2010 at 04:42
chris167
how many bolts have you taken out?
There are currently 1 people online
Most ever was 173 on Sunday 9th Nov 2008 at 8:04pm
Registered Users: chris167
Posted 25th May 2010 at 04:50
kezman7
Erm i didnt count them Ill let you know tomorrow after iv had a look if i cant see anything, Also while im here, Is it heavy off the engine? Is im on my tod
Posted 25th May 2010 at 04:51
chris167
aslong as your not laid looking straight up at it you should be ok Smile
Posted 25th May 2010 at 04:55
kezman7
Haha no no doing it from the top Smile
have you removed the clutch arm? although if it hasnt even seperated at all then this wont be whatts stopping it, yet anyway.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th May 2010 at 05:14
kezman7
No i havn't iv removed the shafts, mount and the cables and alot of bolts
Posted 25th May 2010 at 05:20
This caught me out. I undid everything and could only get the box to come away about an inch or so. Wiggling it for about 20 mins until I found out about the clutch arm Doh
Posted 25th May 2010 at 16:25
kezman7
Did it! I missed an allen bolt down the back Smile Dropped off without me even touching it, Good job i moved my foot seconds before as i only had trainers on.
Posted 26th May 2010 at 02:59
birk
i dropped a gearbox on my hand when i last did mine, oh yea it hurt, was twice the size of my other fingers for a few days, lucky not to break it the doc said. Smile
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 26th May 2010 at 03:10
rallyestyle
WHat did you drop it onto kez? Carefully placed cushions or something?
Probably need to do a clutch change and shaft seals this summer Doh
Just Drive It
Posted 26th May 2010 at 14:58
kezman7
dropped it onto an old bed duvet then slid the lot out the arch
Posted 26th May 2010 at 18:27
yeah they are pretty heavy aren't they! you might want to get someone for putting it back on, Stan306 helped me with mine I had to get under the car and do a push up with the gearbox while he hooked everything in place defo not a 1 man job unless you can use an engine crane etc?
Posted 26th May 2010 at 19:22
kezman7
It wont be going back on so thats ok! Thats why i get garages to do work involving gearobx or clutch, as i have to work on the driveway. Much easiler and safer to give someone like Carl the job Big grin
Posted 26th May 2010 at 19:49
SteviePut
RichW has this down to a fine artLOL
I've helped two or three times now putting it back. It usually takes us about 20 minutes to get it back on - to a stage where you can get a few bolts in to insure the clutch fork is engaged in the bearingSmile
Posted 26th May 2010 at 23:51
jonnie205
20mins? blimey its only about 1 min to get the box from the floor and up onto the engine with a bellhousing bolt in
Posted 30th May 2010 at 00:27
gilesy
Abd I bet if anyone said they'd been to Tenerife you'd say you'd been to Elevenerife.
Always a black cat about hey Stevie? Haha
Posted 30th May 2010 at 05:57
jonnie205
LOL
Posted 30th May 2010 at 15:03
t11hac
LOL
I done my box outside my sister on the street with cars and bus's passing couldnt be helped was very very unsafe Whistle good fun though Dry
Team Black Rallye
Posted 30th May 2010 at 21:26
I think Steve meant completely refitted, not just perched on the ouput shaft with one bolt in Wink
Posted 30th May 2010 at 22:51
jonnie205
yeah that sounds about right, Razz
Posted 30th May 2010 at 22:56
tvrfan007
Does the box not have locating dowels to take the dead weight?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 1st Jun 2010 at 12:49
Yes, but they don't engage until the box is pushed fully home, the whole time you are fiddling around trying to get it to line up though the weight is up to you to support.
Posted 1st Jun 2010 at 14:50
opbk
I don't know how you blokes get your boxes out so easily! Mine was a nightmare. Took me hours to get the bas**rd out. First off there wasn't enough room to back the box out and get the shaft out, then there wasn't enough room between the suspension and the air box at the front so had the box sitting on the diff at the back and the lump for the start motor at the front of the bay.
... Haven't tried to get it back in yet either... :S
Posted 7th Jul 2010 at 09:15
