displaying posts 26 to 33 of 33
Pages (2): 1 [2]
Author Subject: Gearbox Removal
most people here either remove the airbox, or already have K&N filters.
also removing all the shafts first, and the speedo drive housing makes it a lot easier.
also, most drop the engine off the top mounting and lower it on a trolley jack so the casing misses the inner wing.
Posted 7th Jul 2010 at 13:37
opbk
I'll be looking at a K&N - if only to avoid putting the airbox back in.
Shafts came out first as did the speedo housing. Didn't drop the engine off the top mounting, but I did put trolly jack under it to be sure Smile Trying to source all the bits now: those whites bushes the fork release arm sits in, clutch cable, driveshafts seals and crankshaft seal. Am I missing anything?
Already got the clutch kit Wink
Posted 8th Jul 2010 at 08:09
in an ideal world some flywheel bolts, but if not just some threadlock and a torque wrench.
Posted 8th Jul 2010 at 15:10
funkymonk
Sorry to resurrect an old thread but I have my box almost all the way back on, talking literally 10mm tops gap. I can get the bolts in but is it safe to pull it in using them or is it still missing something?
Clutch fork is tucked behind the release bearing and it looks far enough in that it should have slid into the friction plate so I am a bit confused! Tried jiggling and swearing at it but doesn't seem to help!
There are only 10 kinds of people in this world, those that understand binary and those that don't...
Posted 27th Jul 2011 at 21:22
heliosphan
Mine was at this stage for ages, it was the splines not lining up correctly. It took one whole day of wiggling, then a mate came over which helped. It will slide right up to the block with no resistance whatsoever when you do finally get the splines lined up. It's just a pig doing it. Dry
May not be best to use the bolts to pull it in.
Posted 27th Jul 2011 at 23:03
tvrfan007
Stick your fingers in the gap and turn the input shaft slightly. Failing that, push it into a gear and spin the diff with your fingers.
It's the splines not lining up correctly as above, I had this but was putting the box on the engine off the car so was much easier.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 28th Jul 2011 at 11:19
no dont pull it in with the bolts, you will duck somthing up.
keep trying and eventually it will slide all the way in, then put bolts in.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 28th Jul 2011 at 20:51
May be easier to get a helper to turn the engine over slowly with a ratchet on the crankshaft pulley nut as you give the box a wiggle and try to get it to fully engage?
Posted 29th Jul 2011 at 16:55
Pages (2): 1 [2]
