Author Subject: Urgent help please!
cwspellowe
Argh f*cking argh, spent the day cleaning the engine bay and thought "you know what, let's paint some bits".
All went swimmingly as you can see from these before and after shots:
Until I put it all back together. On first crank fuel started p*ssing out of the regulator and I realised i hadn't put the circlip in, and then i noticed fuel coming out of one of the injectors.
Took the fuel rail off to put the injectors back in properly, replaced a couple of o-rings again and put it all back together.
Now when it starts, it chases up to 2000rpm and drops back to idle like a pulse. The throttle is uber sensitive with the car seemingly thinking WOT as actually at ¼ throttle.
Took the throttle body apart and checked and cleaned all the sensors and it made no difference. Everything's plugged back in where it should be, except for one plug you can see in the video. Don't think it was plugged in to anything before but it's got me wondering.
From the way the car's acting it sounds like an electrical fault to me with the TPS seeming to be the most likely culprit for the weird throttle but I dunno, maybe you guys can suggest something?
Here's a video of the revs chasing at idle
Video
And some random thing I found on the floor, don't even know if it's off the car?
Bye bye Sundance Kid Sad
Posted 24th May 2010 at 03:56
mangledmetal
sounds more like an air leak on the inlet manifold bud!
Going through the gates of Hell Backwards, in a ball of flames!
I'll, save you a place!!
Posted 24th May 2010 at 04:07
craigy_87
could there be an air leak anywhere?
i cant say i'm knowledgable enough but sure i've seen something similar on another engine
Posted 24th May 2010 at 18:20
cwspellowe
Hmm inlet manifold gasket maybe? Replaced it the first time i had it off, then used a combination of the new filter and gasket sealant the second time.
All the other hoses are on tight, what's confusing me is the throttle response. Would an air leak cause it to be over-sensitive?
Posted 24th May 2010 at 04:10
cwspellowe
PS engine bay looks nice ey? Laugh
Posted 24th May 2010 at 04:11
Incorrectly adjusted throttle cable Whistle
Posted 24th May 2010 at 04:14
cwspellowe
LOL nah i may be a muppet but i know how to do a cable. Butterfly closes fully with just a tiny amount of slack on the cable. It's like the TPS is reading the resistance totally wrong.
Posted 24th May 2010 at 04:16
cwspellowe
Doh just thought, I had to take the manifold off AGAIN to fix the fuel rail leaks and forgot to reapply sealant!
Fingers crossed it's a quick 30 minute fix tomorrow morning or i'm using public transport for the first time in months LOL
Posted 24th May 2010 at 04:55
cwspellowe
Problem solved, it was the inlet mani gasket.
Replaced and upgraded thanks to Craig with a shiny new PTFE one Cool
Lovely throttle response now btw too
Posted 24th May 2010 at 18:12
rallyestyle
So simple Smile Looks nice and smart the engine bay, good work Thumbs up
Just Drive It
Posted 24th May 2010 at 20:31
oecken
Looks stunning chris, a lot of work to get the inlet that clean?
Posted 24th May 2010 at 20:56
cwspellowe
Nope, I have new tools and supplies, jobs are getting done much more "properly" now. And easier too. Could probably dress yours up in about 3 hours now I know my way around the ancillaries Smile
Don't worry, i'm still a pikey at heart. I used an o-ring off the hosepipe to seal the fuel pressure regulator Laugh my ass off
Posted 24th May 2010 at 23:59
I bet it was the cable but you didnt want to look like a tosser and said it was the inlet gasket LOL
Just kidding,looks good man! Thumbs up
Posted 25th May 2010 at 02:45
cwspellowe
PS it was the cable, I just didn't want to look like a tosser so I said it was the gasket Whistle
Posted 25th May 2010 at 15:34
