Author Subject: big ends gone ???
velar
Under light accelaration there is a engine speed knocking ( sounds a bit like big ends, but it is not always there.)
More noticable at low revs, could this be injector related??
on a Standard engine with no modifications
Posted 19th May 2010 at 23:03
smighall
Smeg-all
If it's knocking most likely to be bottom end, drain oil, remove the sump and have a look for loads of metal
Meh
Posted 19th May 2010 at 23:08
Thought for a moment this was on the rebuilt engine in your car mate, that was a worry. As Sean says, get the sump off, take off some bearing caps and have a looksee. Wink
Posted 19th May 2010 at 23:14
velar
no this is an old car that I have just got going after about 18months standing
Why would it be intermittant.
One evening the car was tapping, next day
Drove the car about 15 miles (stop start) with no tapping. 6 hours later the light tapping was back!!
Posted 20th May 2010 at 04:20
oil change maybe?
or very slightly bent valve Dunno
Posted 20th May 2010 at 04:44
velar
could be a valve, but noise does not seam to be comming from the top of the engine.
It is actually louder inside the car, than with a stethascope on the block, and you can sort of feal it on the pedals!!
Posted 20th May 2010 at 05:13
steps I'd take then,
Drain the oil looking for bits of metal
hopefully wont find any!
if so take the sump off but get it high enough off the floor to give you plenty of room!
it may just be cheaper for an engine swap
off someone reliable on here...
it doesn't sound cheap what ever it is Sad
Posted 20th May 2010 at 08:29
Spark plugs tight?
Posted 20th May 2010 at 14:22
