Author Subject: Ash's 330mm Brembos
psjunkie
will these fit under 17" RSR kahns?
cheers ben
1997 P1 Gti 6 Charged
Posted 19th May 2010 at 17:18
rallyestyle
Probably Yes I dont think they need specialist clearance wheels. However you can never be 100% sure until you try it Smile
Just Drive It
Posted 19th May 2010 at 17:25
psjunkie
Thumbs up
plus what car did your calipers come off or are they a universal type what discs and brackets if any are you running??
cheers ben
Posted 19th May 2010 at 17:30
rallyestyle
My calipers are universal although they are the ones AP use in the 306 kit they sell Yes
I made up my own brackets so that i could run the calipers on 406 Coupe 305mm discs.
Just Drive It
Posted 19th May 2010 at 17:36
ash
Six Addict
I'm pretty sure they will fit with any 17" wheels. i've got over 20mm clearance in all directions on mine (TD PR1.2).
Posted 19th May 2010 at 17:37
psjunkie
cheers ash i will be in touch when ive sourced the bits and bobs i need!!!
Posted 19th May 2010 at 18:39
birk
I had shit loads of clearance when i fitted them on mine with superleggera's
You have to remember the adapters make the the caliper sit back atleast 20mm from the standard fitment on the hub.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 19th May 2010 at 21:16
