Author Subject: Stop light
:: blade ::
hi guys, just a quick question, was coming back from preston tonight, as i was in 6th doin about 70, lifted off to come off at my junction and the stop light kept coming on, would flicker on and off, checked fluids and there all fine, what could cause this?
cheers
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 17th May 2010 at 04:59
cwspellowe
Check your temp sensor plugs on the thermostat housing, one of mine was loose and was causing this
Bye bye Sundance Kid Sad
Posted 17th May 2010 at 05:02
:: blade ::
ok cheers, will check that tomorrow, thats the brown one isnt it?
Black Ph1 XSi-6
cwspellowe
There's three, check 'em all
Posted 17th May 2010 at 05:12
:: blade ::
will do, i cleaned them about 3weeks ago, im sure they were tight, will give them a check tho, what would if be if there tight?
Black Ph1 XSi-6
Posted 17th May 2010 at 05:13
:: blade ::
checked the temp sensor plug, and there all fine,
Black Ph1 XSi-6
Posted 18th May 2010 at 04:20
Lambda could be another.
Posted 18th May 2010 at 04:29
:: blade ::
ok will check that tomoz Smile
Black Ph1 XSi-6
anth
If its flashing like a disco could be he switch.
They get corroded.
Posted 18th May 2010 at 04:49
:: blade ::
its only done it the once, went on the motorway to night to test the car, as ive sorted the exhaust out and it didnt happen, maybe its a 1 off?
Black Ph1 XSi-6
Posted 18th May 2010 at 04:52
monkeyman
Check oil level Confused
Forum Search Clicky
Posted 19th May 2010 at 16:23
:: blade ::
As 1st post oil is fine Smile
Black Ph1 XSi-6
Posted 19th May 2010 at 19:54
