One slider in the kit has a cut out (presumably for the small rubber sleeve) but im not sure which slider goes in which end of the yoke?
Any ideas?
This is the rebuild kit:
Service box diagram courtesy of Cosmic
| Author | Subject: Caliper rebuild help |
fletch
Track Head Location: The nearest Shell garage Registered: 12 Jun 2004 Posts: 12,273 Status: Offline |
Not a GTi-6 but I have a set of 206 GTi Bosch calipers and just bought a rebuild kit.One slider in the kit has a cut out (presumably for the small rubber sleeve) but im not sure which slider goes in which end of the yoke? Any ideas? This is the rebuild kit: ![]() Service box diagram courtesy of Cosmic |
smighall
Smeg-all Location: b*tching and Whinging Registered: 03 Mar 2005 Posts: 10,012 Status: Offline |
Stupid question but have you dismantled them yet? If not then just take them apart and see which ones which.Oh think i've got some standard pads for 206gti calipers you can have too, from when my mum had a gti ![]() ________________________________________ ![]() Seat Leon Cupra FR / 306 GTI6 / Breaking 205 GTI6 / Caterham 7 / Mercedes Sprinter 311CDI LWB Sold: Fisher Fury - Laguna DCI Estate - P1 306 XSI - E30 BMW 325i Baur Convertible - Daihatsu Fourtack - Suzuki GSXR600 - 205 Rallye |
fletch
Yep they were bought without sliders unfortunately been stripped ready to be rebuilt. |
smighall
Hmm, in which case just try the slider without the cutout in both ends of the yoke, if it doesn't go in one end sling the other slider in that one ![]() ________________________________________ ![]() Seat Leon Cupra FR / 306 GTI6 / Breaking 205 GTI6 / Caterham 7 / Mercedes Sprinter 311CDI LWB Sold: Fisher Fury - Laguna DCI Estate - P1 306 XSI - E30 BMW 325i Baur Convertible - Daihatsu Fourtack - Suzuki GSXR600 - 205 Rallye |
fletch
They both seem to go in each one. |
al4x
Seasoned Pro Location: Hitchin Registered: 20 May 2003 Posts: 23,513 Status: Offline |
won't it be the side away from where its mountedto the hub? its so it can move out to compensate for wear and the boot is so it has room to move out |
smighall
Think you've missed the point Alex, Matt knows how a sliding caliper works ![]() ________________________________________ ![]() Seat Leon Cupra FR / 306 GTI6 / Breaking 205 GTI6 / Caterham 7 / Mercedes Sprinter 311CDI LWB Sold: Fisher Fury - Laguna DCI Estate - P1 306 XSI - E30 BMW 325i Baur Convertible - Daihatsu Fourtack - Suzuki GSXR600 - 205 Rallye |
fletch
al4x wrote: won't it be the side away from where its mountedto the hub? its so it can move out to compensate for wear and the boot is so it has room to move out What do you mean by that Alex? The yoke is mounted to the hub by two bolts as per the pic |
fletch
Best suggestion so far:quote: As a guess, I'd say the rubbered slider goes on the side of the caliper nearest the ground, as I think they're designed so you can change the pads by undo-ing the top slider screw and pivoting the caliper outwards revealing the pads. Then it'd make sense that the lower slider would have some sort of in-built pivot or something. |
rallyestyle
Seasoned Pro Location: London Registered: 23 Jul 2003 Posts: 14,991 Status: Offline |
The above makes sense to me mate. By the looks of it the little rubber sleeve is slightly larger in diameter than the general slider diameter so it grips the yoke when inserted. Id guess when the top slider is removed the caliper can pivot on the bottom slider and swing down giving you easy access to the pads as suggested. Thats just what id guess at mate, i have never even seen one of those calipers before so i may be wrong ![]() ________________________________________ Just Drive It |
As above, lowest bolt so the caliper can pivot for easy pad removal, my 307 calipers are similar, means you can change brake pads by just undoing one 13mm bolt.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
smighall wrote: Stupid question but have you dismantled them yet? If not then just take them apart and see which ones which. i thought that when changing the rear pads on a mondeo st but the numptys who fitted the old ones had done each side diferent ie 1 wrong 1 right, i contacted ford technical help to find out which was the right way, havent peugeot got a tech helpline? ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
fletch
rallyestyle wrote: The above makes sense to me mate. By the looks of it the little rubber sleeve is slightly larger in diameter than the general slider diameter so it grips the yoke when inserted. Id guess when the top slider is removed the caliper can pivot on the bottom slider and swing down giving you easy access to the pads as suggested. Thats just what id guess at mate, i have never even seen one of those calipers before so i may be wrong ![]() Yeah it makes sense, just you can do that with the 6 calipers and they have identical sliders I believe. |
farmer
Seasoned Pro Location: Southend On Sea Registered: 20 Aug 2005 Posts: 2,245 Status: Offline |
^^^ ![]() ________________________________________ Long live the Sigma 6![]() Team Phase 1 supercharged XBL ID: farmer uk1 |
rallyestyle
fletch wrote: rallyestyle wrote: The above makes sense to me mate. By the looks of it the little rubber sleeve is slightly larger in diameter than the general slider diameter so it grips the yoke when inserted. Id guess when the top slider is removed the caliper can pivot on the bottom slider and swing down giving you easy access to the pads as suggested. Thats just what id guess at mate, i have never even seen one of those calipers before so i may be wrong ![]() Yeah it makes sense, just you can do that with the 6 calipers and they have identical sliders I believe. Design evolution? Maybe some of the 6 sliders were seizing to the caliper or something hence the rubber sleeve on the 206 calipers ![]() ________________________________________ Just Drive It |
