displaying posts 126 to 150 of 195
Pages (8): first .. 5 [6] 7 .. last
Author Subject: 4-2-1 gti6 manifold
matty_rallye
Post #126
Yea i will get the results up when its done, only trouble is i have changed the exhaust to a 2.5" system aswell. So wont be a definite indication as the old system which turned out to be a 2" bore may have been restricting things slightly.
2.1 16v 306 Rallye.
Posted 29th Apr 2012 at 08:50
Post #127
Quite possibly...
My system is a 2.5" so I am definitely interested in the results. Yes
Posted 29th Apr 2012 at 08:58
Post #128
clen666 wrote:
With regards to exhaust, aren't supercharged applications more closely related to n/a than turbo?
There are still exhaust pulses to factor in without a big turbo disrupting them
This is what I'm thinking.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 29th Apr 2012 at 11:24
Post #129
Lets get "jimmyhackers" involved, hes bound to have a scientific take on the situation to add to the discussion. LOL
Posted 29th Apr 2012 at 13:05
Post #130
LOL
Posted 29th Apr 2012 at 16:16
Post #131
Yes, but it is still forced induction therefore the gases will be moving much faster on the exit than N/A...
N/A is looking for better ways of getting those gases to flow so that they exit quicker, whereas with a forced induction setup the gases are being blown out the chambers into the manifold at a much higher velocity therefore gas flow speed isn't such a great challenge to find as it is on N/A, which is why I would imagine you'll see a good gain with a 4-2-1 on an N/A car and not so much on a forced induction car.
Not strictly true Stan, the exhaust gasses will only be 'blown' down the exhauset as you say when the throttle is open and both inlet and exhaust valves are open on overlap. As SC 306s use standard cams the overlap is very small so very little of the chargers extra pressure will go towards expelling spent exhaust gasses. What will be far more benficial is the gasses natural tendency to fill the vaccum bieng created by the last pulse of exhaust gas still traveling down the pipe towards the exit. If the primaries, secondaries and ciollectors are specifieed correctly (for a given rpm range you will get better cylinder scavenging and a more efficient/powerful air/fuel mix with the next stroke.
Personally I think there could be some useful gains to be had with the right exhaust setup which is going to be in this case a 4-2-1.
Posted 29th Apr 2012 at 23:46
Post #132
I see your point Jim, but I am still thinking along the lines of this:
I am running 454bhp / 320ft/lbs torque. What more would I personally stand to gain by purchasing one of these manifolds? Dunno
Posted 29th Apr 2012 at 23:52
Post #133
More power and torque, oviously. I was'nt debating wether you should do it or not, I was saying there is more to be had if and when someone decides to persue it (Ashley Hargreaves for instance)
Posted 29th Apr 2012 at 23:57
Post #134
That's a good idea...
I would love to see what advantage it could give to someone like Ash, especially as he is doing well anyway with his current setup. Cool
Posted 30th Apr 2012 at 07:10
Post #135
I thought ash already had
A 4-2-1
Manifold
Posted 30th Apr 2012 at 10:07
Post #136
A 4-2-1
Manifold
He does, I was using him as an example of someone who would obviously want to maximise the outright potential of his SC conversion as every ounce of power counts in racing.
Posted 30th Apr 2012 at 10:44
Post #137
Ok, however he is only running 410bhp though. Granted this is restricted to help gearbox life, but I would be REALLY interested to know a torque figure...Cool
Posted 30th Apr 2012 at 13:41
Post #138
Which charger has he got? a 38?
Posted 30th Apr 2012 at 13:57
Post #139
Quoted from his project thread.
Total Car Weight 908kg / 988kg with driver
335bhp/250lbft at 7,000rpm
C30/94 Rotrex running 15.5psi boost
8:1 CR
Wossner 86.0mm Forged Pistons
PEC H-Section Rods
660cfm Siemens Injectors
Shortened/ & Ported Standard Inlet Manifold with Trumpets removed
Ford Ka Expansion Tank
MJS Fabrications Alloy Radiator
MJS Fabrications Alloy Intercooler
Mocal Engine Oil Cooler
Mocal Supercharger Oil Cooler
360mm Slimline Electric Fan
Emerald ECU
Manifold Group A Manifold
Decat
2.5" Jetex Downpipe to Exhaust Joint
Blueflame Cat-back Exhaust System
Posted 30th Apr 2012 at 14:00
Post #140
That may be an old spec though as some say he's got more power now?
Posted 30th Apr 2012 at 14:02
Post #141
On the recent thread Denis put up about Ash racing, Rich posted that he is now running the bigger C38 'charger Yes
Posted 30th Apr 2012 at 14:04
Post #142
Ok, So hes got a bigger charger but at the same power (I.e its all way lower down)
Posted 30th Apr 2012 at 14:06
Post #143
It's not the same power, he was running 335bhp on the C30 charger, now he's running 410bhp on a C38. Yes
There just doesn't appear to be any info on the new setup's torque figure...this would be very interesting. Cool
Posted 30th Apr 2012 at 14:47
Post #144
in his application a broader punch of power would be most welcome rather than the linear delivery you get on the road biased conversions.
Posted 30th Apr 2012 at 15:52
Post #145
I agree and although mine is predominantly a road going application, I would think my midrange would benefit indefinitely from more torque which is why I'm interested in the figures. BHP is great, but if I could improve upon the 320ft/lbs I've currently got that would be awesome. Smile
Posted 30th Apr 2012 at 16:06
Post #146
I'd be very interested in getting more low down power
Posted 30th Apr 2012 at 17:32
Post #147
Have you mapped yours yet buzz? You should have the most low down power of all with that charger I hope? Greedy bas**rd Razz can't have it all for yourself Big grin
Posted 30th Apr 2012 at 17:55
Post #148
Nobody has thought to increase the speed of the charger so it's boosting earlier and providing more low down grunt.
Posted 30th Apr 2012 at 18:05
clen666
Post #149
I had thought about this too, but I think the kit had been designed to reach peak input shaft speed at the top of the rev range, fitting a smaller pulley would mean it's operating outside of its efficient range Dunno
Team 'unintentional rat look'
Posted 30th Apr 2012 at 18:41
fatlapit
Post #150
removing the trumpets will probably not help it tbh
Posted 30th Apr 2012 at 18:47
