Author Subject: leak
craigy_87
when i moved the car today i noticed a wet patch from where the front right of the car had been sitting
at first i thought it might be leakin engine oil but the undertray is on an the patch didnt look like the right place for it to leak through that
i then looked through the wheel arch an the bottom of the spring an the cup it sits in were wet
is this likely to be a badly leaking damper?
Posted 9th May 2010 at 05:10
dommo
Possibly brake fluid, or even PAS fluid?
'99 306 Meridian TD with Bosch fuel pump - Cheap veg oil motoring
'99 Xantia Activa turbo - not cheap veg oil motoring Sad Goes around corners well though
Posted 9th May 2010 at 06:17
craigy_87
hmm anyway to make a distinction between each of these fluids just as it was a brown-ish colour
Posted 9th May 2010 at 06:21
Damper fluid normally smells slightly sweet and it's quite thin.
Posted 9th May 2010 at 06:24
craigy_87
this was quite thin, didnt give it a good smell though, i've parked the car differently tonight see if another patch appears
i believe the damper was leaking very slightly already an yesterday i was having a spirited drive an sure the car got all four wheels off the ground which wasnt pleasant for the suspension not sure if that has made the situation worse
Posted 9th May 2010 at 06:31
craigy_87
i thought to begin with it might be leaking from what ever is behind the plastic here
but i think it may just be dripping onto that
some pics of the liquid that had been coming down the droplink and drippin to the ground
and the damper
Posted 9th May 2010 at 22:07
allesclar
that defintely looks like PAS fluid Yes
Team allesclar ®
Posted 9th May 2010 at 22:23
craigy_87
it looks slightly different colour in the pics (looks more red-ish in the pics)
but if it is PAS fluid where is it likely to be coming from?
Posted 9th May 2010 at 22:34
craigy_87
i seem to get the same colour liquid when i touch the damper shaft (not as much though) , dunno if thats just a coincidence though
Posted 9th May 2010 at 23:55
smegal
I'd say that's a REALLY f*cked damper. PAS fluid is really red. There aren't many fluids it can be other than brake fluid.
I'd check your brake fluid level just in case!
Ex SC-6
Now in a Megane R26
Posted 10th May 2010 at 00:04
craigy_87
i have another set of dampers waiting to be fitted (just need some springs first)
all levels seem to be fine looking at the max an min points on the bottles i'll check again though
Posted 10th May 2010 at 00:07
PAS fluid is quite similar to damper fluid Wink
Just a lot thicker, so if this is thin and looks similar to PAS fluid....
Probably popped the top shaft seal.
Posted 10th May 2010 at 00:08
craigy_87
hmm guess i'll be having the front suspension changed sooner than i thought
Posted 10th May 2010 at 00:12
craigy_87
Clicky
are these the eibach springs i'll be needing
i have a set of bilstein dampers here just need springs to get this problem sorted
Posted 10th May 2010 at 18:42
craigy_87
well should have these replaced soon
are there any other parts i should consider replacing while i'm there?
Posted 11th May 2010 at 18:22
craigy_87
should be sorted soon
got this lot now
Posted 22nd May 2010 at 05:49
cwspellowe
I'll build them for money off the gasket, or I could buid and fit them for all the money off the gasket Wink
Bye bye Sundance Kid Sad
Posted 26th May 2010 at 02:56
