Author Subject: Fecking ARB end plates stuck
cwspellowe
Hey fellas, haven't even had chance to fiddle with the torsion bars 'cos i can't get the fecking ARB end plates off. I've been using an M12 x 1.75 bolt as recommended, the bolt was put in straight on, and... the end plates got threaded on both sides. Brilliant. Kinda sets the tone for the TB's i guess...
But anyway, is there anything else i can do now? Or is all hope lost?
Bye bye Sundance Kid Sad
Posted 9th May 2010 at 02:13
cold blows with a small chisel mate that aways works
Posted 9th May 2010 at 02:36
chris with a pug
have you tried prying the end plate off? grinder maybe?
if not what about tapping the trailing arms outwards to take it off?
Posted 9th May 2010 at 02:38
smegal
Where did you hear about using m12X1.75?
FAQ wrote:
M12x1.5 threaded Bolt
Ex SC-6
Now in a Megane R26
Posted 9th May 2010 at 02:51
paul_13
I use a peugeot bolt, normally works never tried a ford bolt. Never stripped the threads though.
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 9th May 2010 at 03:07
allanallen
The thread is m12 x 1.5. I usually use a slide hammer to get them off, seems to work better for me than the 'winding a bolt in' method
Anyhow Jack the car up, remove both wheels, undo both arb end plate bolts (m8/13mm). Get a 10mm punch and put it through one of the knackered m12 holes then smack it with a big hammer until it pushes the arb out. It may bugger the top of the m8 thread up in the arb but you should be able to dress it up and chase the thread out.
HTH
Facebook
Posted 9th May 2010 at 03:46
simonjames
I've had a few stuck on end plates i spray penatrating oil through the hole leave over night then put the air gun on it following day
MY EBAY ITEMS
07943066306
Posted 9th May 2010 at 16:27
wrong bolt fail Doh
I would fit an M8 bolt into the threads of the ARB on the Right hand side, and knock the ARB out of the end plate.
find an end plate fropm a scrappy and replace the R/H one (you dont take the left hand one off ever so no need to replace it)
all zx/xsara/306 end plates are the same, but specific left to right.
Posted 9th May 2010 at 23:20
