Author Subject: To start or not to start?
fozzy_255
Ok short story is i bought a cheap gti6 with engine damadge. Picture explains it
Went up a steep kerb took out underside of the front. holes in sump, snapped driveshaft and snapped gearbox mount OUCH!
The guy said he turned it off striaght away but to be honest can never trust private sellers so i took it as a fooked engine.
I now have another sump. i was planning on rebuilding the engine.
But i wondered if i should try fitting new sump and filling up the oil and seeing if it will start.
Is this a very very bad idea or if damage is already done then no more can be caused.
I may sound a bit Blink Crazy but i just had the idea.
Any help appreciated thankyou
John
Posted 7th May 2010 at 04:10
jay_gti6
if it wont cause anymore damage so to speak and if it already could be F**cked then what you got to lose in respect i could be wrong but nothing tried nothing gained lol Big grin
N.C.F.C
GTI-6 black
TEAM PHASE 2
TEAM BLACK GTI-6
TEAM COST-A-LOT-IN-FUEL
Posted 7th May 2010 at 04:20
fozzy_255
hmmmm, your on my line of thinking.
But what if they really had turned it off just intime so there is minimal damage would starting it up cause more?
Will be removing sump and getting my dad to check for me as hes done engine rebuilds whereas i know sweet FA.
I plan on learning fast though Smile
Posted 7th May 2010 at 04:23
jay_gti6
i dont think it will cause anymore damage as if you fill it with oil im sure it just like doing a oil change if he did turn it off if he didnt then its fooked anyway live life to the full give it a go lol if it works you could save hundreds if it dont you got to spend it any way aint you Big grin
N.C.F.C
GTI-6 black
TEAM PHASE 2
TEAM BLACK GTI-6
Posted 7th May 2010 at 04:32
mark-house
Start it up if it goes bang put a new engine in it cheaper and quicker than a rebuild
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 7th May 2010 at 04:33
tea boy
Why don't you just whip no four big end cap off whilst the sump is off?
Then you will know.
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 7th May 2010 at 04:36
jcphat
First, sump off and have a look.
Try turning it over by hand with a socket on the crank pulley- ignition off and plugs out-if it turns over then sump on fill with oil and try it on the starter-plugs out, in each case listen. If it won't turn over or makes bad noises stop. If it turns over OK then give it a go- if the bottom end has run without oil it will tell you quite soon.
A second hand engine may be a better economic bet than a rebuild- carl (mechanical-repairs) was recently selling several.
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 7th May 2010 at 04:38
jonnie205
fit a new sump, i am almost certain the engine will be fine. If the shaft was snapped and gearbox mount broke i cant see him leaving it running
Posted 7th May 2010 at 16:52
bung new sump on and fill it up and run it, see how it sounds. if the impact/force was quite bad, the inertia switch should have turned it off anyway Unsure
Posted 7th May 2010 at 16:56
bobdylan_55
try turning it over by hand as said, if it seems smooth i cant see there being any problems
309 GTi6-T
Posted 7th May 2010 at 16:59
or stalled, not many people remember to press the clutch when in the middle of a crash, too busy concentrating on other matters.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 8th May 2010 at 03:51
fozzy_255
Thanks for all the input. got the car up in air ready to take sump off. has taken a hard hit. has a nissens rad though which seems to have survived (how i don't know)
Its stuck in gear as the gear linkages have come off and cant seem to find one to put back onto the ball thingy no idea of its real name :s
Hopefully will crack on with trying ideas out tommorrow.
Posted 8th May 2010 at 04:07
fozzy_255
Just took the sump off a spare bottom end i bought and found this in the sump
Thin bits of metal (not the pad thats just there to give scale)
Where could it be from?
Posted 9th May 2010 at 16:51
cooper666
big end bearings
he might have run it longer than said
clio r27
ps3 id:cooperkloe
Posted 9th May 2010 at 17:17
fozzy_255
Ah ok, this wasn't the car im fixing, i bought this bottom end knowing there was problems but i just wanted the sump, plus get to practice on a spare before i touch the real one.
Posted 9th May 2010 at 17:22
pete_rallye
Thats off a spare bottom end? Not the holed sump one? If so you're spare bottom end is f*cked! They are bits of bearing basically, if you ran that bottom end it would knock like f*ck, probaly seize up and smash a hole in the block pretty quick...
Lap of the 'ring
Posted 9th May 2010 at 17:24
fozzy_255
yeah spare one that was knocking, but like i say i just wanted the sump. But is good to have one sitting on a bench so i can learn from it.
Havn't taken off the broken sump yet. weather has been rubbish plus i need to know how to take the chain off the pump so i can remove it to check out the bottom end properly.
Posted 9th May 2010 at 18:28
khj100
When you take the old sump off, check for any signs of metal. Obviously bits as big as your example a sign of complete bearing disintegration, but if it's been running a seconds without oil the pieces will probably be smaller.
If you don't see any immediate signs of damaged bearings you can either drop the shells off an inspect them quickly (gives piece of mind) or just stick oil in and try it. When you do start it, listen for any signs of knocking at between 1.5 - 2k rpm.
Posted 9th May 2010 at 23:02
fozzy_255
Well i got the engine started today, started up no problem. Bit tappy though.
Now i can get the engine out and start stripping apart. I think the engine must have had a snapped cambelt at some point thats why its tapping
Posted 15th May 2010 at 16:58
