Author Subject: Backing off jerk?
vernam616
Right ive done a search and cant determine what my problem could be.
Jumped in the car tonight and instantly noticed that whenever i back off the throttle, the car jerks ever so slightly forward, almost as if its deaccelerating too quickly, i cant figure out from my search whether im having problems with the clutch or lower engine mount?
any help appreciated
Dan
Audi S3 Black Edition
Posted 1st May 2010 at 00:48
lower or top engine mount.
Posted 1st May 2010 at 00:50
allesclar
agree, engine mounts have gone Sad
Team allesclar ®
Posted 1st May 2010 at 00:53
greenbelt
Top engine mount Yes
Standard Black 6
Black HBSC6 Smoke
Posted 1st May 2010 at 00:55
vernam616
How can you change a engine in a car and not change the mounts whilst its out?
Sick as f*ck with this
Posted 1st May 2010 at 01:01
vernam616
Ive got a lower engine mount bush, there seems to be a lot of shit flying about as of how to change these, many people say you need a press and they are a pain to do, and others say they are easy Crazy
So... ive got a new one of these lower engine mount bush's kicking around in the garage, how easy of a job is it to change this bush and is that all i need to do?, im fairly sure whilst Carl had the engine out if he noticed the top mount cradle was cracked he wouldnt leave it damaged
Posted 1st May 2010 at 01:04
i reckon it the lower mines doing this at the moment if i let off the pedal quickly and jump back on to it.look under the car and grab the mount you'll feel loads of movement i bet
vernam616
well im changing the exhaust tommorow so will have a look, the job of changing the bush looks fairly easy as it has a metal casing around it, so like the FAQ just cut the old frame out -- bash it through -- slide new one in? and bolt it back up
Posted 1st May 2010 at 01:07
Most likely will be the bottom one. They can still look ok but be tired enough to move considerably.
Posted 1st May 2010 at 01:09
allesclar
during any engine change, you should change/check the mounts, end of.
Team allesclar ®
Posted 1st May 2010 at 01:14
greenbelt
Mine used to do this before I got the top mount welded up.
Standard Black 6
Black HBSC6 Smoke
Posted 1st May 2010 at 01:45
daveyboyholt
I bought a 2nd hand lower bush mount. Local garage charged me a fiver to press old bush out and pressed a new bush in ready for swapping straight over. Saves a lot of hassle.
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 2nd May 2010 at 03:11
jimmy9gti
Not on our old diablo Royston, surely not!!.
Never even looked at the top mount all the time i had that car mate,was spot onSmile .
Miss that 6 Sad .
Posted 3rd May 2010 at 00:59
greenbelt
Miss that 6 Sad .
LOL
Definitely not the diablo!
Standard Black 6
Black HBSC6 Smoke
Posted 3rd May 2010 at 02:32
mechanical_repairs
If there was a problem with the mounts they would have been changed, has the car only just started doing this?
Carl
Posted 3rd May 2010 at 03:39
smaller
I had this exact problem several weeks ago and think it's largely been cured by fitting a new lower engine mount. I changed the OEM one for a Powerflex polyurethane item and the difference is very noticeable. Feels like a lot less 'give' (for want of a better description) with throttle inputs resulting in forward motion of the car rather than the engine moving around.
I should add that I'm a bit of a mechanical novice and found the FAQ guide helpful. It took a while to cut through the outer metal casing of the old bush and my advice would be to first off have a decent junior hacksaw where the blade (and numerous spare blades) can be locked into position, and secondly make sure you're cutting straight which is easier said than done. When I say straight, I mean not at an angle as your might when cutting through some 2x4 wood, as in this case, you will start to saw into the mount casing itself - best avoided Wink
Blaze 6
Keep It Standard
Posted 3rd May 2010 at 03:44
that bottom engine mount bush is a right barsteward to even press out, well it was on mine anyway.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 4th May 2010 at 00:02
