Author Subject: Vernier Pulleys?
itchytrigafinga
Hi All,
I've got some Newman PH2 cams for the 6. and i also have some hydraulic lifters.
I dont however have vernier pulleys, and was advised to get some by the garage that is eventually going to be fitting them so they can be timed up correctly.
My question is, can i just buy any make of vernier pulleys for the cams or does it have to be specifically newmans ones? Can i buy kent pulleys etc and use them ok?
Cheers,
Will
Posted 14th Apr 2010 at 15:20
Should be fine, however if you are unsure, conftirm this with the supplier before handing over your cash.
Posted 14th Apr 2010 at 15:39
itchytrigafinga
Have checked with Newman’s and you can use any pulleys, any ideas which is the cheapest place to get them? (I'm not getting them off eBay!).
Newman’s don’t actually produce Pulleys for the 6 yet so I can’t buy them from Newman’s.
Posted 14th Apr 2010 at 18:52
Piper do a set, for about £190 I think
Posted 14th Apr 2010 at 19:46
Pretty sure Catcams and BakerBM do a set too?
My Piper one cracked in two...Hmm
Posted 14th Apr 2010 at 19:52
Rich E Forum Admin
IIRC Kent supplied vernier pulleys to Peugeot Sport.
Whatever brand you choose make sure the inlet pulley has the trigger for the cam sensor.
Posted 14th Apr 2010 at 23:44
itchytrigafinga
Ok i dont think i will be getting Piper then,
Would these be ok?
http://www.motorsportworld.co.uk/detprod.asp?productcode=KC-CA78&PID=364892
I guess they would have the so called trigger for the cam sensor?
Posted 14th Apr 2010 at 23:52
mabgti
NV motors
cat cams is what i'll be ordering.. tru lock pulleysYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 15th Apr 2010 at 01:46
Piper definitely don't have a crank sensor trigger.
Posted 16th Apr 2010 at 05:54
itchytrigafinga
Dont quite understand but isnt that a bit useless if it doesnt have the trigger? I mean assuming they specify they are for the 6 but then dont work?
I have ordered some from Kent, contacted them before hand and they do have the trigger on the inlet pulley.
Posted 16th Apr 2010 at 17:35
They are only for cars with aftermarket ECUs.
Posted 16th Apr 2010 at 17:41
itchytrigafinga
Its going to be used with an aftermarked ECU, A DTA E48. So i guess it doesnt matter then?
Posted 16th Apr 2010 at 17:46
Nope Smile
Posted 16th Apr 2010 at 17:50
