Author Subject: Standard suspension replacement?
motorman
As my rallye restorations has progressed it has become clear that the little french piece of shi*e is on need or more tlc than i first though...
I will now be replacing all the suspension parts, starting with solid mounts. I then want to change the shocks but i will be retaining the standard ride height.
Can anyone offer any suggestions on shock choice & replacement standard height front springs please?
Posted 11th Apr 2010 at 02:38
monkeyman
Bilstein B4/ Eibach are the usual recommendations, not sure if Eibach do a regular height spring, but likely.
Forum Search Clicky
Posted 11th Apr 2010 at 16:32
anderoo
If you want to keep it standard height why not use standard parts?
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 12th Apr 2010 at 17:42
motorman
Because i'm looking for suspension that is a little firmer than standard.
Posted 12th Apr 2010 at 18:57
Replace everything for decent standard stuff, add a stiffer rear ARB and good tyres. Then take it from there - it will be a load better than shagged old stuff thats for sure.
Posted 12th Apr 2010 at 20:59
craigy_87
the B4's are standard spec dampers
Posted 12th Apr 2010 at 22:18
Nope they are 10% stiffer than standard if i remember right craig
Posted 13th Apr 2010 at 00:22
motorman
I have just fitted a set of uniroyal rainsport 2 to the car, so tyres are fine.
It is mainly the back end that is worn out, so I figured to change all 4 shocks for b4's, modify my old beam mounts into solid ones. Take if from there once i see how the car drives?
Posted 13th Apr 2010 at 00:47
gazzerdaman
B4's will make the car sit high on standard springs
Gary
Cherry Red GTi 6
Posted 20th Apr 2010 at 04:49
