Author Subject: ph3 headlights to phase 2
7057sam
i have a set of clear ph3 headligths.the wiring is abit of a mess on the car atm so will change the wiring relay aswel.my question do i need ph2 or ph3 wiring an wat else will need changin over .
many thanks sam
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 10th Apr 2010 at 15:47
As your search button seems to be broken i will answer this for you Roll eyes
To fit ph3 crystals to a ph2 car you need to remove the adjustors off the ph2 lights and fit carefully to the ph3 lights.no wiring changes are needed
Posted 10th Apr 2010 at 16:39
7057sam
ok thank you .sori dude
Rallye dead Sad
Posted 10th Apr 2010 at 16:43
sehr_gut
I was doing the same work on my ph.2 yesterday, too, when I found I need to swap the adjusters. One question: Is there any release / trick removing the ball-rod from the holder in the light housing? Or do I just need some decisive pull to remove it?
Posted 23rd May 2010 at 18:32
mechanical_repairs
Turn the adjuster so its not fixed to the light and carefully just pus down on it so the ball socket slides out the slider, refit the same way.
Carl
Posted 23rd May 2010 at 21:57
sehr_gut
Cool, thanks Carl!
Posted 24th May 2010 at 20:27
