Author Subject: undoing brake bleed nipples.
cliff7110
am going to bleed the brakes on the car tomorrow and have pre soaked the nipples in wd40. its been a long time since they were last undone so do want to risk shearing them. would it be ok to use an electic impact gun to take shock them off or is it a big no no?
any help would be great
cheers
Cliff
Posted 8th Apr 2010 at 20:57
mr swampy s16
**BAD SELLER**
No!
I use a deep socket on a qtr drive and never sheared one yet
Posted 8th Apr 2010 at 21:10
^^^ 6-sided socket on a ¼" drive and shock it loose rather than just applying pressure, 99% of them come out fine then.
Posted 8th Apr 2010 at 21:16
cliff7110
ok will do that.
so give the rachet a good tap with the hammer?
Posted 8th Apr 2010 at 21:19
tvrfan007
No harm in giving the nipple a lovetap before applying your good 6 sided socket.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 13th Apr 2010 at 07:28
sixygti2
Well thought I'd use this instead of my own thread.
Whilst trying to undo the rear nipple, it did shear off as has happened so many times before.
I want to try and get what's left out hopefully by hammering n a torx bit or something, but I was wondering if its ok to spray WD40 around what's left of the nipple with the hole going straight into the caliper.
It wont cause any harm/damage if it gets in will it? Unsure
Tanks
Still watching you...
Posted 14th Jan 2011 at 04:31
heliosphan
If the nipple didn't turn at all before it sheared (which I'm guessing is the case) then the hydraulic circuit should still be completely sealed I think. WD40 ingress should, therefore, not be an issue.
*Awaits prompt correction Whistle
Posted 14th Jan 2011 at 04:52
sixygti2
No the nipple didn't turn at all!
Ok, should be fine then. I guess I could just stuff something in the hole to block it if I have to.
Still think it's going to a be a bugger to get out though!
Posted 14th Jan 2011 at 21:33
Rich E Forum Admin
Just bear in mind that if you start hammering a Torx bit into the remains of the nipple you will almost certainly break through into the hollow part and start leaking fluid.
Posted 14th Jan 2011 at 23:02
smegal
I'll be impressed if you can get it out. Just give it a try and get a new one if you need to.
Ex SC-6
Now in a Megane R26
Posted 14th Jan 2011 at 23:05
sixygti2
Ok rich, noted!
Its off the car as it's a spare caliper so will hopefully be able to easily catch watch does leak out or soak it up!
Thanks
Posted 14th Jan 2011 at 23:50
Rich E Forum Admin
Ah cool, if it's off the car then there's nothing to worry about.
Posted 15th Jan 2011 at 00:04
blaze wip
A liberal application of plusgas, a cuppa while it sets in, a pozidrive bit in an impact screwdriver, ONE good smack with a bfh and a standard pozi screwdriver should see you right. Wink
Dont forget to have the replacement nipple to hand before you start.
EDIT: Scrap the last bit with it being off the car. Thumbs up
mechanical_repairs wrote:
i feel like giving her a good dry bumming session.
Posted 15th Jan 2011 at 00:09
sport1901966
I would recommend some carefully applied heat also. You'd need to be sure you've done all you can before starting to take them off because by the time you realise its turning it'll either be ok or have sheared.
Rears are definately worse, I havent had a problem with fronts so far..touch wood!.... but had a few rears go on me.
Good luck!
Posted 15th Jan 2011 at 02:38
sixygti2
Thanks for the tips guys, will try to sort it over the weekend!
Thumbs up
Posted 15th Jan 2011 at 03:19
sixygti2
Sodding torx bit snapped in the sodding bleed nipple!
How does that happen!!??
May try drilling it out now... I dont wanna give up on it yet LOL
Posted 15th Jan 2011 at 19:32
Don't think you will be able to drill it out with a torx bit stuck in thereSad
Posted 18th Jan 2011 at 03:29
Nope, the high tensile Torx bit will be harder than the drill. If you want to stand a chance and you can get at it use a grinder to flatten off the broken bit, then centre punch it ecactly in the middle, if you can find a way of clamping on and securing a drill bush over the broken bit even better. Use a pillar drill and plenty of tapping fluid and you just might get away with it. Only thing is to stop drilling as soon as you have reached the end of the broken off bit. The nipples are relatively soft and if you go all the way through and damage the aluminium seat at the bottom of the hole tyhe caliper is scrap anyway. New ones are'nt massive money though so if it takes more than an hour or two it really is'nt worth the effort.
Posted 18th Jan 2011 at 03:35
The torx bit is relatively hard so with cheap drill bits you'll need to go slow on the revs, plenty of pressure and make sure the tip is lubricated with moly-d or similar. If you go at it full tilt you'll just overheat the tip of the drill and it'll go soft as shit.
Posted 18th Jan 2011 at 03:58
sixygti2
Thanks for the advice guys.
I did give it a go, but as you say, the torx bit was hard as! So gave up.
I did manage ti strip the bits off I needed, sliders, piston etc, as they were in better nick than mine. So hopefully i'll be able to get some new rubbers and swap them over. Was just hoping I could swap the whole thing as I knew it was a good working one. Hay ho, you live and learn.
As its the second time this piston has stuck out and ground down the pad, could it be the handbrake mechanism or is it just the fact that the sliders and piston are showing signs of corrosion and its not able to retract?
Posted 18th Jan 2011 at 04:28
Disconnect the cable, if it moves freely in its outer sheath then it has to be a problem with the slider mechanism (Most likely this as it usually is)
Posted 18th Jan 2011 at 13:43
ksung17
mine were seized. and got told of a friend to apply heat which worked a treat!
Posted 1st Feb 2011 at 04:27
i think heating them up or wd40'ing them liberally beforehand works a treat, combined with proper brake spanners. i've never had an issue with them rounding off or siezing in whatsoever yet touch wood
Posted 1st Feb 2011 at 15:10
405gti6
Blow torch is the weapon of choice when loosening these suckers. With enough heat they almost fall out by themself!
XU10J4RS powered 405 Big grin.
Posted 22nd Feb 2011 at 21:08
