Author Subject: Massive play/movment
kezman7
I have had the problem of a horrendous knocking and banging noises from both front wheels but mainly the Drivers side, Went to see a my cuz's flatmate who is a mech and when wiggled with the car still on the floor the whole assembly moves in all directions and makes a banging noise whilst doing so.
He seems to surgest the TRE's but that one was new in september. Its lowered 60+mm atm but im looking to raise it 10-20 to get more clearance with the smaller wheels and also get some handling back.
I have noticed that the CV grease seems to have been leaking as theres a small amount sprayyed afound the area(large end) which was also fitted a gen pug one at the same time as the TRE. Could this also be contributing to the noises?
Posted 8th Apr 2010 at 04:46
mark-house
when you say the whole assembly moves do you mean the whole strut? the shock spring droplinks etc?
and who is honendios? sounds like some mexican football player lol
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 8th Apr 2010 at 04:44
kezman7
Yep the whole lot, wishbone, wheels all moves. I noticed that when you go on or come of throttle it also bangs and knocks the steering wheel slightly
Posted 8th Apr 2010 at 04:47
mark-house
what condition are your strut tops like? the bearings in them have a habit of drying out and turning to dust. this combinded with lowering it 60mm could have shagged the rest of your suspension bushes causing the play.
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 8th Apr 2010 at 04:53
kezman7
Im not sure TBH they look good, no cracks in rubber ect but this may not show that there knackered.
Posted 8th Apr 2010 at 04:54
mark-house
only way to tell is to drop the strut out and check them. but if your gona raise the car then you will have to do that anyway. its worth checking over all the suspension rubber as if these haven't been changed they will more than likely be on their way out or be totally shagged.
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 8th Apr 2010 at 04:59
sixysix
Would be best to jack the car up and check all the suspension and steering parts for loose or missing nuts/bolts.
Also check the bushes for play, although I don't think they would cause the kind of sounds you describe even if they were shagged.
With that much movement, I would say not to even think about driving it until you find the cause of the problem Sad
I take it you checked the springs as well?
Good luck with it Smile
Take a look
Posted 8th Apr 2010 at 05:17
kezman7
Luckily i dont need to drive it very often atm, Pain is i work 6 days and have college the 7th so getting time for stuff like this is a nightmare. Will get the spanners cracked out then hopfully next week
Posted 8th Apr 2010 at 05:18
greenbelt
Would be a good idea to check all the subframe bolts as well
Standard Black 6
Black HBSC6 Smoke
Posted 8th Apr 2010 at 05:46
subframe bolts and wishbone bolts
Posted 8th Apr 2010 at 05:49
greenbelt
And the ball joint clamp nut Wink
Standard Black 6
Black HBSC6 Smoke
Posted 8th Apr 2010 at 05:53
