Author Subject: Rear ARB lost splines.
velar
I am a bit confused/ suprised.
Just removed the rear ARB and found that the splines at one end are not engaging. It appears as if the end plate splines are a different size to the bar splines.
Because it has not been engaging for some time the splines on the lower side of the end plate have worn away.
Are there different size splines/end plates?
Should I replace the whole unit or just the worn end plate.??
Posted 6th Apr 2010 at 22:46
greenbelt
They are different at each end Paul. Make sure you are using the right end Wink
Standard Black 6
Black HBSC6 Smoke
Posted 6th Apr 2010 at 23:11
darkgti6
I have a GTI-6 ARB with a nearside end plate on if you need one . . . . . . . for some beer tokens obviouslyWhistle
Team Peugeot Sport 308 Gti
Posted 7th Apr 2010 at 00:22
velar
If the ends are different, it looks like someone has fitted the wrong end on the Offside( should this be the smaller of the 2?)
The nearside end is OK, so need a ARB plus offside plate.
Posted 7th Apr 2010 at 03:30
greenbelt
The offside is smaller end Yes
You should only be able to slide the bar in from the nearside when fitting. And you need to get the offside plate off first when removing it.
Standard Black 6
Black HBSC6 Smoke
Posted 7th Apr 2010 at 03:41
velar
Thanks for the info, looks like I need a offside end plate. Angry Whistle
Posted 7th Apr 2010 at 14:41
