Author Subject: Oversteer
asim_pug306
I'm currently in ownership of my 3rd 306 so I know all about the handling characteristics of them. However this is the only one that's been lowered so I think this could be causing the problem.
Was driving along the dual carrigeway today doing about 60 around a slight bend and I kept feeling the back end go a little. It wasn't lift off oversteer as I had the throttle on slightly but it felt really odd as it's never done it before. Could it be the torsion beam playing up?
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 5th Apr 2010 at 06:08
lotek
crap tyres , worn beam mounts, incorrect tyre pressures Thumbs up
Posted 5th Apr 2010 at 06:47
lotek
also was the road bumpy or rough?
Posted 5th Apr 2010 at 06:48
asim_pug306
Not really I use that road regularly and it's never happened before. Tyres are going to be changed next week so I hope it is crap tyres
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 5th Apr 2010 at 07:43
oldbrownshoe
It doesn't have to be bumpy or rough, if the turn has negative angle even if you can't see it could throw the back as well .
one of the wildest overseers i have experienced caused from that.
French military victories?
Did you mean French military defeats?
Posted 5th Apr 2010 at 10:28
asim_pug306
Right this still hasn't been sorted and I've put 2 new sets of tyres on since so that's ruled out.
Could it be worn beam mounts/bushes?
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 2nd Jun 2010 at 02:44
pooouk
I would guess at knackered P bushes or balljoints.
Nick
AKA nick on 205gtidrivers.com
Posted 4th Jun 2010 at 02:21
jarrus464
well when you lower a standard car it does adjust the camber slightly on the front (more negative) that could be the problem
Posted 9th Jun 2010 at 16:51
asim_pug306
Finally found out the problem. It was a worn ball joint, there was loads of play in it so the wheel wasn't as still as it should be.
I think the description I gave was a bit misleading but that's the way it felt. Car feels spot on now Thumbs up
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 9th Jun 2010 at 20:32
jord294
judging by the state of your old rear beam, i don't think the worn ball joint was your only problem
(your message inbox is full)
Posted 5th Oct 2011 at 18:36
LOL epic thread bump
Posted 5th Oct 2011 at 18:42
cwspellowe
Laugh
Yeah, get told!
Bye bye Sundance Kid Sad
Posted 5th Oct 2011 at 18:47
jord294
LOL
i only thought it was a few months old, then realised it is actually 2011 Roll eyes
Posted 5th Oct 2011 at 18:54
