Author Subject: coilover issues
ken
hi peoples.
im having issues trying to put the top nut on, when i try the whole shaft spins round.
it says on the suspension not to use grips!
would i get away with using grips or fit them on with them not done up and with the pressure will go?
any advice on this please.
thanks
ken
Team Black Rallye Big grin
xbox live - Xx 7 kenny 7 xX
Posted 1st Apr 2010 at 19:45
Fit them, get some weight on them, try again.
If that doesn't work you'll want to grab the shaft with a rubber strap wrench, or very carfully with a couple of bits of thick cardboard in the jaws of some mole grips.
If you mark the shaft the oil and gas will p*ss out every time it goes through the seal
Posted 1st Apr 2010 at 20:03
no allen key hole?
Posted 1st Apr 2010 at 20:51
rallyestyle
Yeah it should have an allen key hole in the top i would have thought. Can just use a swan next spanner and a torque wrench to do it up then Yes
Just Drive It
Posted 1st Apr 2010 at 21:09
Depends if they're adjustable coilovers?
Posted 1st Apr 2010 at 22:36
mxcrazy
They're spax so have the adjuster on top.
Posted 1st Apr 2010 at 23:28
ken
there the ones mxcrazy were selling a while back!
but just got the issue of getting it in the cup now we go to sort.
Posted 2nd Apr 2010 at 01:11
An air impact gun usually does the trick to get going as its easier to spin the nut than the whole shaft, but I'm not sure if your adjuster is too big to get a socket over?
Posted 2nd Apr 2010 at 01:20
jonnie205
air gun every time
Posted 2nd Apr 2010 at 04:37
ken
thanks for the help geezers.
anyone got any advice on how to get it in the cups? or know or a tool to widen them a lil bit?
:S
Posted 7th Apr 2010 at 01:05
cups?!
Posted 7th Apr 2010 at 01:40
ken
lol i call them cups. Where the damper sits ontop of the hub Smile
Posted 7th Apr 2010 at 14:06
