Author Subject: Ball joint extenders
tez_306
Hi there,
For those who've lowered their 306's quite a lot, you'll notice the front lower control arms sit at quite an angle. This is what causes 'bump steer' which is basically loss of straight line stability upon suspension bound and rebound.
Now, in the VW scene were the focus is on extremely low and flush bodies - there have been ball joint extenders developed.
These however are 17mm in diameter. Our pugs use 16 and 18mm.
Do any of you know of alternatives? I'm thinking about buying them and sleeving them.
Cheers.
Posted 27th Mar 2010 at 18:23
tez_306
Heres another example
Posted 27th Mar 2010 at 18:27
without measuring the effects of extreme lowering on bump steer changes these would be pointless.
I would prefer to have some suspension travel and not be a scene slave Thumbs up
Posted 27th Mar 2010 at 18:52
tez_306
It has nothing to do with the scene, i merely pointed out that there are ball joints available for golfs because there's a large market for them in comparison to 306's.
I haven't measured it, but I know for certain that my control arms sit past the parallel point to the ground and its only mildly lowered. I plan on lowering it further and this will only increase the angle at which the control arms sit. As long as the roll centre is past the parallel point, there will be bump steer which I have experienced time to time at speed.
Posted 27th Mar 2010 at 19:14
mabgti
NV motors
sounds gud... but think it'll be more efficient just to design a rose jointed balljoint.. a simple flat laser cut steel with a welded in joint..
it makes sense, as with roller bearing bushes, bump steer is more apparent..Yes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 28th Mar 2010 at 00:00
rallye1999
i thought the way to avoid bump steer on lowered cars was to raise steering rack or space the track rods lower down
Posted 28th Mar 2010 at 02:07
^Bingo.
Otherwise you're changing the instant roll centres, so you have to be sure you're doing exactly what you want.
Not a bad idea, but I'd be very wary about the leverage on the hub with that last one!
Posted 28th Mar 2010 at 02:39
mabgti
NV motors
so is it possible to space the steering rack higher up??
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 28th Mar 2010 at 03:55
to a certain degree yes, though not sure how much space you have to play with.
Posted 28th Mar 2010 at 04:06
tez_306
The steering arms is the other aspect to consider - depends on who you ask. Generally bump steer is defined as the tendency for the vehicle wheels to steer (toe out/in) upon suspension bound.
But the way I see it, bump steer will occur over two circumstances -
* Alteration of track - as the control arms move upward, the track of the vehicle decreases [ie the wheels move *inwards* towards the car]. This can bounce the vehicle to the left or right depending on which wheel (on the same axle) has more load on it at the time.
* Alteration of length of steering arms - as suspension bounds, the effective length that the steering rods need to be to maintain zero toe changes.
Another way to change steering arm angles is to use rose jointed tie rods spaced downwards from the hub knuckle as opposed to spacing the whole rack up. But however, like the above method of dropping ball joints - will place extra strain on the joint. Heres an example -
This is something i've considered for a while - I'm surprised to not have found any information on this forum about it - some of you guys have super low cars!
Posted 28th Mar 2010 at 06:32
mabgti
NV motors
ive been thinking bout it loads too, but phillip is the man for that shit!LOL
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 28th Mar 2010 at 06:55
jonnie205
the second picture looks horrendoues, that will surely break instantly, way to much load for a thin bit of bar
Posted 28th Mar 2010 at 23:19
Bottom of the hub will go oval in short order.
Posted 29th Mar 2010 at 00:46
