Author Subject: pulling to the right
craigy_87
i've just had the wheel alignment done on the car but although its a million times better now, it still seems to pull slightly to the right.
they done it 3 times to try get it corrected but the garage believed something else might be causing it to pull, what other things could be causing it?
cheers
Posted 24th Mar 2010 at 18:00
what condition are the suspension bits in?
A mate had this on his car and in the end a set of new tyres sorted it out LOL
Posted 24th Mar 2010 at 18:02
craigy_87
its had new track rod ends
second hand wishbones but with the new P bushes and ball joints
i think one of the shocks may be dying (slight leak) though would this cause it
Posted 24th Mar 2010 at 20:21
second hand wishbones but with the P bushes and ball joints
Maybe,havent got a snapped spring perhaps?
Posted 24th Mar 2010 at 18:28
craigy_87
hmmm i cant see it snapped anywhere but i'd need to look again
surely they would see that though when looking over it today LOL
Posted 24th Mar 2010 at 18:31
Snapped spring perhaps?
Posted 24th Mar 2010 at 18:39
hbinky
I had a snow tyre on my old diesel which was the cause of my car pulling widly to the right, only found out after 3 lots of tracking. Just had a single front spring changed at christmas and this also resulted in severe pulling to one side until I got the other side changed. Springs or tyres is could well be.
Posted 24th Mar 2010 at 18:46
craigy_87
aint the tyres but spring/damper might be a good shout
Posted 24th Mar 2010 at 18:51
lotek
see if your balljoint pinchbolt is loose.
Posted 24th Mar 2010 at 20:07
but don't over-tighten them! 23lbft off the top of my head.
Posted 24th Mar 2010 at 20:08
wishbone bushes or caliper
Posted 24th Mar 2010 at 20:11
craigy_87
when they came in to the reception bit to ask if anythin else had been changed recently apart from the track rod ends i told them about wishbones, surely they'd have checked that.
i'll double check to be sure
lotek
Tell me about it , ive snapped mine about 20mins ago. no car till whenever then new ones turn up! Dry
Posted 24th Mar 2010 at 20:22
craigy_87
just had new P bushes not long ago an the front bush looked in decent condition.
so list so far is
snapped spring
pinch bolt and
caliper
adamski_306
Mine pulled to the right, it turned out to be the suspension top mount and bearing.
Posted 24th Mar 2010 at 23:51
idboo
Same here, just changed the top mounts on mine, the right bearing was shot, only pulled slightly to the right before but tracks perfect now.
Posted 25th Mar 2010 at 00:02
gilesy
I asked Ash the exact same question yesterday...it was tracked with no one realising it had a random 55 profile OSR. Anyway I replaced the balljoints and it slightly pulled left.
I then got some correct 55 profile wheels tyres and it then started pulling right (as you would expect as the radius on the NS tyres was now larger.
I have taken it to 3 different Kwik-fit branches and it will take about 8-10 seconds at 70mph to go from one lane to another on a motorway, still to the right.
EDIT: My car has new P bushes, balljoints, TRE's, droplinks and discs/pads within last 1000 miles.
Posted 25th Mar 2010 at 01:56
craigy_87
hmmmm the guy at the garage did mention something about my top mounts
Posted 25th Mar 2010 at 02:39
chrisd306
buy my shockies mate and i will get you some bearings for your mounts and be sound, shouldnt be the pinch bolts as i fitted them and they were new mind.
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 25th Mar 2010 at 04:38
adamski_306
This is what mine was like, its definatly worth checking your top mounts.
Posted 26th Mar 2010 at 16:03
