Author Subject: Rear Brake Pad Area Q
iplay
The recommended rear Ferodo DS2500 FCP558H leaves an inner and outer lip on the disc. Ferodo FCP558H Pad Dimensions: 105.20 x 42.00 x 11.00 mm.
Can anyone recommend a Ferodo rear brake pad that sweeps the entire disc area?
Posted 22nd Mar 2010 at 05:43
The only ones that I've seen that are deeper are the Bendix pads for the front calipers on the 1.4 - 54.3mm deep
But they require some modification to fit!
Posted 23rd Mar 2010 at 05:11
iplay
phillipm wrote:
The only ones that are deeper are the Bendix pads for the front calipers on the 1.4 - 54.3mm deep
Like the ferodo FCP565H for the fronts? i need larger rear ones?
Posted 22nd Mar 2010 at 05:56
The front calipers on the early 1.4 are a wider version of the rears, but using deeper pads.
Only problem with using them is the pad is thicker and there's no retainer for the piston. FBD393 is the part no.
Posted 22nd Mar 2010 at 06:08
iplay
Using Bendix FBD393 sounds like I will have to fabricate a retainer and remove some pad material? (and I can't even get a door to shut atm!)
What about using a rear disc from a clio. I think they use the same rear pad as a gti-6 ... Ferodo FCP558H but list a slightly smaller rear disc and do not get a lip.
Posted 22nd Mar 2010 at 16:49
Yep, you'd have to get some fabrication done.
I can have you some custom made but you'd better sit down before the price LOL
Posted 22nd Mar 2010 at 21:28
davedgti6
Could the callipers not be spaced out a touch more? I.e. further out from the centre of the wheel? or would this end in disaster LOL
Posted 23rd Mar 2010 at 04:29
gilesy
Are you really noticing the difference of miniscule amounts of braking force?
I doubt it
Posted 23rd Mar 2010 at 04:49
I think he just wants a pad that gets rid of the rusty lip...
Posted 23rd Mar 2010 at 04:53
allesclar
sorry phillipm, but you are saying that unlike the fronts where you could use say a lancia delta DS2500 front pads to get rid of the rusty rings, this is not possible at all in the same way on the rears?
Team allesclar ®
Posted 23rd Mar 2010 at 05:03
The only pads I've spotted that might do it were the FBD393 with a bit of modification, but I've never really looked into it seriously - I'm on drums so it doesn't bother me! - so there may be other pads somewhere.
allesclar
ah ok, thanks Smile
Team allesclar ®
Posted 23rd Mar 2010 at 05:12
iplay
I doubt it
purely cosmetic! although once the lip gets to 2mm it does impact on the edges of the pads.
Posted 23rd Mar 2010 at 19:43
once the lip gets to 2mm its time for new discs LOL
Posted 23rd Mar 2010 at 20:13
^^ LOL
Posted 23rd Mar 2010 at 20:33
oli h
Silly question, but how do you get around fitting pads without the piston retainer notch.
I have some unused 1144's here which are for a front bendix caliper of some sort. They're of identical dimensions to the rears on my 205 1.9 so thought I might use them somehow??
Posted 23rd Mar 2010 at 23:48
iplay
Doh LOL
Posted 24th Mar 2010 at 00:07
